help please! what size of mid-pipe and muffler is the best?
angdaoni
Hi expert bros! :adore:
I m really new into mods and would like to get some advice from experienced bros.
I am driving a Manual 2006 cs3 mitsubishi pre-face lifted Lancer. currently i have changed my extractor to 4-2-1 and a waja dummy cat( izzt wat it is called? from wat i see, its just a box and a pipe straight thru it).
I am only looking more for low end power for pick up and acceralation.
What would be the best size for mid pipe?
and what would be the best for muffler? should it be full flow or semi flow?
what other mods can i do for low end power for pick up and acceralation?
I have also done simota carbon charger but using back the stock air ram. would things like the simota sprial "fan" work?
btw, would also like to ask, to increase my braking power, do i change all as in the brake pads, steel hose? or just steel hose would be enough?
please help me bros! thanks a lot!!:adore::adore:
GT_AUTO
3,501
71
K.Trg
www.facebook.com
what type of engine bro?btw,change brake pad first then hose.if u got no
problem with ur budget,do it all together.u can feel the improvement.
angdaoni
engine is stock mitsubishi lancer cs3 pre-face lifted.
i dunno the number leh..
angdaoni
hi bro, i lost u somewhere back there.. hahaa..
and what would be the best for muffler? should it be full flow or semi flow? all this for low end power for pick up and acceralation
tofu_manic
1,342
91
how many cc is your engine? best would be a free-flowing straight-flow muffler if you can bear the noise, or just find one with a really big tong, so less noisy hehe
use smaller rims n tires :D
boyzone
2,669
light weight sport rim with reasonable tire width.
if u car is Auto, u need back pressure to gain good low end torque.
angdaoni
I am driving a 1.6l stock Manual 2006 cs3 mitsubishi pre-face lifted Lancer. currently i have changed my extractor to 4-2-1 and a waja dummy cat( izzt wat it is called? from wat i see, its just a box and a pipe straight thru it).
Thanks experts!:adore:
[Joc]
172
hi angdaoni,
well i think the most you should go is about 2 1/2inches for your mid pipe, and go for a straight flow muffler (you're calling it full flow). That helps acceleration.... but if you don't wanna be so bold then go for the 2 1/4inch pipe and muffler, helps with the noise if you think loud cars are unbearable.
[Joc]
172
mmm, true GT_AUTO... but some people believe to restrict a little so you get more high end torque, esp with automatic transmissions you use S-Flow mufflers, forsaking acceleration.... hence in theory, if u completely remove the exhaust system you get good acceleration but u lose torque... is that correct?
angdaoni, maybe you might wanna go for 2" or 2 1/4" inch, cause i agree with GT_AUTO with it being a bit too big...
angdaoni
o icic, so for low end, pickup, acceralation, i should go for 2" pipe and straight flow muffler for my 1.6l manual lancer??
tofu_manic
1,342
91
yes, i think currently 2 inch would be enough, have it follow ori route if can...
All work and no play makes Jack a dull boy. Now while playing it safe isn’t always the most sexciting option, sometimes taking the secure route is the logical choice as secure and safe is most likely the dependable selection as well. And you can’t go wrong with dependable, especially in regards to picking a car based on your monthly pay...
