water injection for turbo usually use the pressurize air (boost) from turbo to "push" water from sealed water container (with controlled vent) to inlet pipe after air filter or turbo.
appropriate nozzle to make small mist of water droplets required to make sure it "blend" with intake air.
water injection benefit from colder air intake temperature and thus some power increment can be felt.
I'm planning to change my driveshaft, not only that, i wanna change the full set alone.
Ok, i don't know what is that called.
Assuming the driveshaft alone is on the right, in the middle is the steel rod, and on the left is also similar like driveshaft but is not.
The reason why I want to change is that, there is this 'kling kling' sound even when driving on straight road, i suspect is the steel rod or the one inside. There is no 'tak...
