fit oil cooler, oil temp and pressure 4G15
abunawas
80
43
518
hi i recently got a new project car a wira 1.5 manual in stock condition. i would like to add an oil cooler and gauges, oil pressure and oil temp.
can anyone recommend a good shop that can fix all this for me?
the oil cooler is maybe not needed for now, but i may change the engine later when budget allows, for now i just want the oil cooler and gauge.
i checked mudah , a lot selling the cooler and relocating kits from half cuts, but i am not sure if they will fit?
the 4G15 use similar connection to other cars for the filter?
thanks.
Half cuts I don't know. But I know most if not all general fit-all coolers will fit the 4G15. Works, Hayden all will fit if your adaptor is purpose fit for the 4G15.
abunawas
80
43
518
thanks for the reply. i will start shopping around. will look at a suitable adapter or maybe they come in kits too. with so many 4g15 fitted already i think they should be very common.
ken yeang
6,617
1,327
some new kits come together with adaptors.....
Half cut items dont usual comes with adapters
abunawas
80
43
518
thanks.
guys, those with 4G15 fitted with oil temp and pressure, mind sharing what your readings are? mine is stock, so i need a baseline just to see if my engine is in good health?
Erm... oil press at cold is 80 and warmed up about 20 I think. I need to check again. Oil temp when hot is about 98 and cold is just ambient temp.
Nissan’s first in-house hybrid technology will debut under its premium Infiniti brand and will eventually filter across to its more expensive RWD sedan models to ensure that all hybrid vehicles it sells will remain profitable. Nissan already offers a hybrid model in the form of its Altima sedan but this car relies on a petrol-electric hybrid system sourced from Toyota. Nissan’s first proprietary system will arrive in 2010 but it’s not clear...
