Evo1 jerking badly..
guitarman
Aug 29, 2015
29
44
hi.. anybody ever having this experience with 4g63t evo 1 engine.. it happen to me few times already this week..?
any suggestion.. what could possibly go wrong.. :(
Need more info, like how it is jerking? Initial drive, slow speed, fast speed etc.....
guitarman
29
44
usually during slow cruising speed.. the engine suddenly shaking jerking like u "batuk teruk" :D then it fine..
i dunno lah people say the Mpi Relay is bad.. some other people said the coil or the power TR is bad.. i just know how to drive only... :o
6UE5t
6,000 RPM
6,756
1,300
Start from the easier and cheaper things to do first:
1. Check and clean your spark plugs.
2. Check also your plug wires.
3. Clean your injectors.
4. Carbon clean your throttle body and intake.
guitarman
29
44
i think the best way is to look for a workshop with a scan tool.. at least the engine got a chance to say something...
:o:):D
jebatdex
430
18
518
Skudai, Johor
:o:):D
Scan tool can tells exactly what is the problem? or give some indication of what is the problem? Cause my satria also jerking, 4G92P, still wondering what to replace after replacing the distributor and plug cable did not resolve the problem.
Hi, i'm currently using Myvi SE1 with abs system. Recently i thinking to change my rear drum brake to disc brake.. will it effect my ABS system? very confused on this.. some people say that ABS will not able in drum brake.. so if myvi with abs system only for front disc brake ?
