Evo1 jerking badly..
guitarman
Aug 29, 2015
29
2
44
hi.. anybody ever having this experience with 4g63t evo 1 engine.. it happen to me few times already this week..?
any suggestion.. what could possibly go wrong.. :(
Need more info, like how it is jerking? Initial drive, slow speed, fast speed etc.....
guitarman
29
2
44
usually during slow cruising speed.. the engine suddenly shaking jerking like u "batuk teruk" :D then it fine..
i dunno lah people say the Mpi Relay is bad.. some other people said the coil or the power TR is bad.. i just know how to drive only... :o
Start from the easier and cheaper things to do first:
1. Check and clean your spark plugs.
2. Check also your plug wires.
3. Clean your injectors.
4. Carbon clean your throttle body and intake.
guitarman
29
2
44
i think the best way is to look for a workshop with a scan tool.. at least the engine got a chance to say something...
:o:):D
jebatdex
430
18
Skudai, Johor
:o:):D
Scan tool can tells exactly what is the problem? or give some indication of what is the problem? Cause my satria also jerking, 4G92P, still wondering what to replace after replacing the distributor and plug cable did not resolve the problem.
TrailBlazer69
Oct 22, 2015
31
4
Kota Kinabalu
There is a problem in your car's wiring bro. i've been in your place as well. I've tried all try and errors but still the same jerking on slow cruising. Suddenly, the culprit is actually a wire touching to the others. Make sure to recheck your wiring bro :nurse:
u have yr own preference i have mine mah... i have traveled the long journey of mods.. i wont wanna waste my time on it.. been there done that.. i wanna go next phase mah.. so i leave the earlier hard road of mods to u to travel...
