evo 3 to overhaul or not
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
if do overhaul....
ill probably do a checklist like this:
1-forged conrod
2-forged piston
3-acl/king race bearing with +1 size than original (to compensate crank and/or conrod bearing wear/machining repair)
4-metal head gasket
5-new oilpump kit
6-timingbelt kit
7-oilseal kit
8-waterpump
9-pretty much all new silicon hose
10-get spare turbo (probably rebuild with billet compressor wheel along the way)
11-emanage to tune to new engine power potential
12-new fuel pump
13-new fuel regulator (adjustable preferred)
14-all new mounting
15-spare driveshaft
16-spare 3k for gearbox rebuild (usually tendang-gear simptom happens on high mileage mitsubishi) caused by worn synchro
thats it...
---------- Post added at 11:08 AM ---------- 6 hour anti-bump limit - Previous post was at 10:59 AM ----------
my overhaul cost me this on 4g93 na..
this is workshop bill only not include part that i buy my self..
so plan wise before you do major work to ur engine..
eeekkkkkk....
waittt..... why in the recipt lists item most of them twice?
#ubahsuai liner- rm700 ok
#grindvalve using machine- rm304 ok
#potong crankshaft- rm220 ok
#skim head- rm80 ok
#then again skim head- rm40??? :confused:
#water test head+block costs rm200??? :confused:
#change valve guide- rm256 ok
all the above machine shop charged already...then why below the bill still add another RM400 for the job paid above? :confused::confused::banghead::banghead::banghead:
ken yeang
6,000 RPM
6,617
1,327
dont forget to add......
ARP bolts/fasterner set, and the cost of engine fluids for flushing/break-in and the subsequent engine fluids, bushes, and some rubber boots (if the ori ones oredi koyak)
fazidk
3,163
413
5,183
Well when I did a full engine overhaul on my ex-vr4 about 2 yrs ago it cost me nearly 8k �� so I assume it wld cost around that much for n evo3 since it's more or less similar engine...pls take note that all parts replaced was original parts NOT forged or race items...so if u opt for those then d cost wld probably double or more...
slipar
500
61
banting - pj
eeekkkkkk....
#skim head- rm80 ok
could not remember correctly but the skim head rm40 one is for upah cos pomen send the head by himself..
the 400 one the charge for piston job & i dont remember exactly what & few time eng. shop visit..the overhaul take month to complete due to my budget prob & me searching for the right piston..so the receipt also like what the pomen remember only..hahaha..if in detail i think the cost is higher..
---------- Post added at 12:30 PM ---------- 6 hour anti-bump limit - Previous post was at 12:29 PM ----------
this is also in the list the item that i buy myself..
Car maintenance not cheap, unless got money, every 5 to 7 years finish installment, trade in get new car, start all over again....hhahahhahaha
peterj
1,321
258
1,683
Kuching
if do overhaul....
1-forged conrod
2-forged piston
4-metal head gasket
5-new oilpump kit
6-timingbelt kit
7-oilseal kit
8-waterpump
12-new fuel pump
14-all new mounting
15-spare driveshaft
thats it...
eeekkkkkk....
#skim head- rm80 ok
this list i totally agree, at least when i plan to do budget overhaul for my own car last time(top overhaul and change piston rings and bearings with arp head studs) , ended up found piston ring groove got crack.. and then alang alang cracked my own pocket to forged all things inside:driver:
ken yeang
6,000 RPM
6,617
1,327
dont forget......6% GST
---------- Post added at 05:22 AM ---------- 6 hour anti-bump limit - Previous post was at 05:19 AM ----------
if do overhaul....
1-forged conrod
2-forged piston
4-metal head gasket
5-new oilpump kit
6-timingbelt kit
7-oilseal kit
8-waterpump
12-new fuel pump
14-all new mounting
15-spare driveshaft
thats it...
eeekkkkkk....
#skim head- rm80 ok
heheheh, while at it, might as well do engine balancing and blue printed.....Baru syoik!
Both also just increased his budget.....lol:biggrin:
ken yeang
6,000 RPM
6,617
1,327
Budget increase oso nevermind, so long got evo monster engine inside.......
Pardon my ignorance and poor bahasa skills, but what is 'potong crankshaft'? You cut the crankshaft??? :confused:
if do overhaul....
1-forged conrod
2-forged piston
4-metal head gasket
5-new oilpump kit
6-timingbelt kit
7-oilseal kit
8-waterpump
12-new fuel pump
14-all new mounting
15-spare driveshaft
thats it...
Dude.. you servicing your car or building a race car? :biggrin:
ken yeang
6,000 RPM
6,617
1,327
Bro, Izso, I think potong crankshaft might mean "crankshaft bought from chop shop".
slipar
500
61
banting - pj
haha.. no la bro..not cut like potong to pieces..
my workshop bawah pokok only that why like that the receipt..
my crankshaft got scratch..have to reground to put oversize acl race bearing..+0.25 now..
potong crankshaft = reground crankshaft in bawah pokok workshop term..hahaha..
before open engine like me only can hope nothing major have to do..
but after open then u know what happen inside..then u like pitam already..
among item that bought my self already cost 1k++:
acl bearing
arp headstud
valve 16pc
valve seal
timing belt kit
piston set
metal head gasket
Similar threads   Forum
  Similar Threads
Need some help here....
Can anyone advise on the difference between the 2 adjustable fuel regulators? Heard that FSE is supposed to be the better one....
