Eterna v6 twin turbo gearbox problem
tembun
35
To all sifus,
Anyone can give opinion on my perdana v6 twin turbo gearbox problem. It is a manual 2wd gearbox but don't know what type.
The problem is the first gear cannot be shifted from free directly. It only can be done either by shifting it very slowly to first gear or shift the gear to 2nd then to 1st gear. If I try to shift directly to 1st gear, there will be a sound like the gear is not in position.
Another thing, got a headache with the perdana rear power window problem. Had got it checked but can only be used for a few days. Afterthat, sorry cannot be used. There is no problem with the switches or the motor itself.:confused_smile:
Any ideas! Thank you
gsrTurbo9166
958
yes bro
i met this gear box problem b4 wif my previous mivec engine
when shift directly to 1st gear got sound like "crack" rite???
i went to my mech n ask him to take out my gearbox n check n he say that the gear inside ( i forgot which part d) got prob n cant fix it anymore.if wan to fix need to order many parts so he suggest me to get another gearbox which cost me cheaper than repair
u may ask ur mech to check ur gearbox
n i hope that ur prob is not like mine which need to change another gearbox
hope this can help
Gen2(Mivec)
10
tembun said:
Thank you, sir.
Bro, 1st of all, is tat the original gear box???? Did change ur clucth plate b4???? the main thing is, ask ur mech to check ur 'flywheel' got 'senget' o not.... k!!:_:
monsterv6
2,531
S.J
tembun said:
To all sifus,
oh that usually happen to v6tt gearbox...i think u have to ask your mec about it..but usually just get a prepare to get another gearbox just incase.....
is not a big problem but......u knw anything can happen........
same goes to me about the bck window....i just leave it cause to headache to fix it everytime...heheheh
killerloop25
94
Its probably your fisrt gears synromesh already wotn out. Mitsu's are famous for that problem. My evo gearbox also the same but its on the fourth as well. You should just opt for the standard 4wd gearbox and install the whole drive system. End to all your problems furthermore its just bolt on.
A Post Every 5 Mins
The Ducati Club of Malaysia will be holding a gathering this weekend with the aim of setting a new record in the Malaysian Book of Records for most Ducati bikes ever gathered in an area. The event, held in conjunction with the Shell Advance Roadshow, will the club partner up with Next Bike, the sole distributor of Ducati bikes in the country...
