A engine with 9:5:1 CR consider as a high compression engine or a low compression one?
Does this engine suitable for turbocharged?
0.4 is abit disappoint eh =Srule of thumb BOT engine....
with stock head gasket,stock piston,stock conrod,stock conrod bearing....
u can boost happily at 0.4bar (*provided with proper tuning on engine management comes along)
Not on CVT....now it is on Auto but will replace it to Manual soon berfore BOT ~Normally BOT safety boost at that level. Sure you can boost to 0.8 but at your own risk. I believe most of the workshop would not recommended especially if on CVT gear box.
Yeah yeah ~ definitely.....cause the original ECU can't read boost pressure signal unless u just "cheat" it....but it will inject same amount of fuel even there is no boost which make the FC worst,black smoke.etc ....but that is a poor mans mod la ~I think your stock ECU cant support your setup atleast you need a piggyback ECU.
