- Oct 16, 2006
- 107
- 0
- 1,516
Dudes,
I just got a new ride and this is my first TURBO and I need advices on what I should/shouldn't do.
how to make sure turbo is cool enough before turning off engine...??Cannonfodder said:Use only synthetic engine oil
Change your oil regularly at 5000km intervals
Make sure that the engine oil is up to temperature before beating on the car
Make sure you cool down the turbo before turning the engine off
If it's a used car, have your A/FR tested to make sure you're not running lean
If it's a used car, do a boost leak test, you're guaranteed to find some
Don't simply turn up the boost without supporting mods
Other than that, it's just like any other car.
Stop boosting and start cruising about 5 minutes away from your destination and your turbo will no longer be spooling and cool enough that you can shut down the engine.t0il3t_duck said:how to make sure turbo is cool enough before turning off engine...??
Speed Demon said:If you do not intend to mod the car and you are leaving the engine as it is, a good FATT (fully automatic turbo timer) is all you need. A FATT will detect temperature levels and sets the turbo timer accordingly to keep your engine running long enough to cool your turbo down.
Since it is a new car, I suggest investing in a good alarm system first before proceeding to buy any gadgets. The more gadgets you have, the more inviting to thieves your car will become.
Just browse the Car Crimes thread to get an idea of what I mean. :X-:
By the way, congratulations on your new car. :regular_smile:
