changing wiring is too much of a hassle.
maybe ill just add resistor pack on my current wiring.
about the ecu. buying an ecu also would costly. what if i rechip it and pair it with my current SAFCII ?
If the man/women/bapok/pondan/transex whom does ur rechip really knows what he is doing, U don't even need to use SAFC anymore. He can actually Copy the whole program from a GSR chip and have it installed into ur new chip.
If he's better than just knowing what he/she is doing, he can even rewrite the whole ignition and AF mapping complete with knock detection igtion retard and etc.
If he/she is the GURU, he can goes into details changing the definition and convert ur engine management system and replace MAF with MAP.
BTW, sorry for the late diagram as I was quite committed with work recently.
Here is the wiring diagram
Here is how the resistor looks like. Below are 10Watt 33Ohm. Look for 10 Ohm 10Watt.
Here is the original MMC resistor pack
speed2horizon: i think what cons with Bot after proper tuning is high fc rite?? i have tune well on my mivec turbo, 1 year already with 1 bar boost (got internal mod) and also big turbo(tdo5h modded fit in tdo6 turbine).. nothing bad just the fc, 7km/L , i concern about fc since i use it as daily car, now downgrading to n/a and mod
![Bawling :bawling: :bawling:](https://zerotohundred.com/forums/styles/default/xenforo/smilies/bawling.gif)
loss power lo
Not really, my car when it was 18+WHP runs 5++km with RM85 RON 97 fuel driving everyday from Cheras to Rawang using the MRR2. What I did was, leaning the AFR to 12-13 and increase the under 3krpm and 30% Throttle position. At 3krpm, tps 40, 12.0 Anything more than 40% TPS, i richen the the AFR. At idle, i targeting for 15AFR.
but one thing lah high compression is dam shiok for daily driving especially in kl when u wanna tarik from one traffic light to another
if low compression must tekan habis so boost kicks in then oni shiok thats why if plan to go for high compression forged pistons for my e3 when budget permits later on :rolleyes: plus im using only 1.3 mm cometic metal gasket now??
what do you guys think about the metal gasket coz i told my mech i wanted to maintain the high compression on my e3 when i sent in for top overhaul so he recommend me change the gasket to 1.3 oni whats the thickness of stock evo 3 gasket??
I really don't understand why ppl want to increase the CR by changing pistons and then reduce it back by adding thic gaskets.
Tarik from traffic light..? tyre can stick..?? Even at stock..?
Nothing is
ONLY abt 1.3mm metal gasket. A stock 4G63T gaskets is only 0.8-1.0mm. When adding 0.3mm, u're reducing the CR.
Internals will never survive severe knocking due to high CR and high boost. Neither ur forgies. The only way to save that is by having a good tunning.
Good tunning = full control of ur injector/ignition timing = Full control of the ECU = rechip/standalones.
Can achieve by emb/safc/other piggies. But also up to a certain limit where ur engine can afford to go further.
super-charged it , anyone ? i'm more keen on SC than TC ... anyone wanna share some basic info ?
SC is not hard. But also require alot of customizing.
First choose the model of SC u wanted.
Then, U need to find a way to mount it, so that it can be drivin by the crank through pullies and belting system.
customizong a piping channelling compressed air into ur TB/manifold.
Might require an additional injector complete with injector controller of other piggyback.
Send for tunning.
However, SC has a boost limit that's controlled by the bypass valve. Upgrading boost are not available unless u modify the bypass valve in the SC itself.
Please understand that eventhough they are both FI system, but they worked in a complete different way...
Turbo = waste to power gain
SC = Sacrifice to power gain
SC not cheap la. nissan march sc can la. but not enuff uumph.
to be honest. i love the lag of the turbo. gave the false feeling of "sudden power" haha.
But what kind of Ump are u looking for when u are only targetting for 0.5bar..?
