RM70 sounded u cut throat the seller. Market is selling ard RM220-RM250 depending on the condition. So, RM70 is dirt cheap.
Resistor pack is to be used on setups with low impedence injectors. Most oF the automotive setups are high impedence setup. When u add in a resistor pack, it becomes a low impedence set up. If not all, most of the turbocharged MMC engines are running on low impedence injectors. I.e. gsr 390cc twintip, vr4 450cc single tip, 450cc twin tip from rvr, 510cc from Eco 1-4, and etc etc. If u are running a high impende with low impedence injectors, u may fCe problem ur ecu not ablecontrol the injector or worse case scenario, u'll burn ur ecu.
So, here u are. U can chose the better looking MMC resistor pack from halfcutt which cost RM50-RM80 depending on seller. Or u can go for the DIY route. Just go into any electronic shop at Jln Pasar and ask for 4pcs of 10ohms AC resistors. They should cost u <RM10. They are white rectangular box like coffin with terminal at both ends. Wannna beautify it, get a VEROBOARD that will cost u RM3.00 so that u can solder them together. Installation is simple, cut the middle of the -ve wire of each injector, connect each -ve wire with a resistor. Have the othe end of the resistors parallel(join) into 1 and go back to any of the Inkector wire returning to the ECU. They are all ground at ECU actually. So, it's better to have it that way. Will draw some lines when I have time.
Regarding the TD05, yes. PNP on a bored up GSR manifold. Just another RM20 to twist the flange angle. But when u boost high, it's highly advised to change ur pistons to a low compression pistons.
G force are adictive. U'll want more. Hehe... Everyone says 0.5bars is enough in the beginning. Before they BOT. Same goes to me. When The TD04 does not overcome ur thirst for Gs, then u'd better leave the cost saving part and have it done properly at the first place itself or u'll end up spending more n more when things turned out to be ugly... Just my 2 cents experience.*
