Changing wira headlight bulbs
eraserwke
120
Subang
Hey.. I'm a newbie to DIY. Just bought new bulbs coz my headlight becoming dimmer dy. Want to try fixing myself. Can any sifu teach? :P I got both the H4 bulbs and the W5W ones. Can teach how to change both? Noneed to unscrew headlight or anything rite?
Supachip
205
puucuung
1. unplug the H4 headlight socket behind the headlamp.
2. pull out the rubber seal behind the headlamp.
3. unclip the pin inside headlamp (put ur hand inside and feel).
4. take out the H4 bulb.
for the w5w bulb, u need to remove the water expansion tank on the RHS and than the socket can be reached easily.
eraserwke
120
Subang
the water expansion tank.. RHS when u're looking at the front of your car? Got this black box thing behind my left headlight. makes me can't reach the screw to adjust my headlight angle. my angle out already i think thats why my lights very dim at night. cannot see far.
huakenny
LB Performance
9,126
240
3,163
Kota Kinabalu
water expansion tank is the spare tank...white color tat one....in front battery....
Supachip
205
puucuung
Water expansion tank is on the LHS if u look from in front of car, white color tank. Black box? I suppose u mean the fuse box. That shouldn't obstruct the light adjustment screw lah. Just use a stubby philip screw driver to adjust, if u using normal long screw driver of cause cannot. The screw of headlamp near to the fender is used to adjust the beam height and the one near radiator is used to adjust width of beam.
Come on, this is easy job lah brother, try again....
eraserwke
120
Subang
supachip: thanks alot =) helped me out. at last i didn't change myself. some workship guy changed for me for free. but not the W5W ones. coz i'm planning to change headlamp too. so wait till get new lamps then change all together. i found the bean height. adjusted quite ok. couldn't find the other screw for the width. haha.
DarkAccoon
880
432
3,063
everyone makes mistakes
why larrr, everyone thinks the shorter the screw driver the easier it is to adjust the headlights
take long long ones
much more easier i assure you
after reading this i bet you will never use those short stubby screw drivers for headlight adjustment anymore
(referring to wira)
as you have already located the screws to adjust the height and width
here is what you do
look from the top and you will see those screws can actually be adjusted from the top
just plug the long screw driver into it and start adjusting larrr
dunnit to screw from the back of the headlights wan
eheheh
some lousy workshop taught me this (more like i curi listen to their conversation)
huakenny
LB Performance
9,126
240
3,163
Kota Kinabalu
who tel u to use short one o? the fella sure fool u
normally ppl use moderate or long one..easier to adjust
take long long ones
(referring to wira)
here is what you do
eheheh
DarkAccoon
880
432
3,063
huakenny,
there, this fella that i just quoted
ehehe
anyway, he was teaching the new guy on the block, not me
eraserwke
120
Subang
From the top? is it the same screw as the one from the back? can adjust from the top meh. zzz.. anyway, i STILL haven't located the width one.. lol. sigh.
Anyone knows where to re-balut back the seat and change the sabut to foam? If possible, make the head rest as well..
I want to find an affordable shop..
