Car Battery lasted for few days only
zainul
29
Malaysia
Been having this issue on my Proton Putra 1999 (Auto) where the battery only lasted for few days (4-5 days) without starting the engine. After that the battery power will drop and i have to jump start or charge the battery first.
There seem to be something sucking the battery but i cant seem to figure out. I've sent it to a nearby mechanic but he can't detect it as well. Anyone can give some idea how to solve this?
ken yeang
6,000 RPM
6,617
1,327
From my experience, it was caused by a faulty ignition switch at steering column. The ignition remained on, even the car key was removed.
Just to share with you.
Being having this issue on my Proton Putra 1999 (Auto) where the battery only lasted for few days (4-5 days) without starting the engine. After that the battery power will drop and i have to jump start or charge the battery first.
Too many possibilities.
1. If you have an immobilizer but had it bypassed or disabled, sometimes if you tap it wrongly the battery will drain big time.
2. Ignition like what Ken Yeang said
3. Your VS is faulty.
Easier to just list out all the things you have that are non-standard in your car.
Also, to test connect a multimeter in series to the negative terminal of your battery with the car turned off and check the ampere draw. Anything above 0.2/0.3 is too high.
LesleyAprotto
Banned
Jun 16, 2012
1,339
287
683
There are 2 possibilities....
1) Your car has got wiring problem, that is there might be bare wires in contact with the car body...
This can happen if your wire is broken or bitten by rats etc
2) Your new battery is faulty...
Certain unethical battery shop will fill in the distilled water instead of acid into your new battery...
At any cicumstances i think you are entitled to change a new battery as it is under warranty...:listen:
Can try locking with the key and do not activate the alarm.
Check also the Audio Head unit. My friend got one time Head unit remains on and draw current too....
Dec 27, 2012
HI all sifu out there,
My Estima's car battery only lasts for 3 months. Earlier I was advised to change the alternator. After changing the alternator,the battery problem remains! Went to Toyotsu, they checked for leaking current, can't find any. They highlighted the alternator does not "store api", advise me to change alternator again! WTF.
Any suggestion?
Any suggestion?
Park the car at home, start it up and let it idle. Open the hood and pull out the battery leads with the car idling. See how long the car idles and if it dies off really fast.. your alternator is in need of changing.
Just changed the alternator about 6 months ago, change again?
test first la.
You changed to a new one or recon unit? If recon then it's possible. If it's new claim warranty. If it's not the alternator then you have a current leak somewhere (but your mech confirmed there wasn't any right?)
Last possibility is you a zillion voltage stabilizers and they are faulty (does happen). Take it out and try.
Any suggestion?
Alternator charge the battery, don't store. If they do not know what they are doing, better find another mechanic....
They just need to check charging rate (voltage) of the alternator. If below level then only need to change. Looks like they do not know what is wrong so trial and error but you pay for it....:banghead:
i just buy sparco bonnet pins(imitation). Thanx raymond ftzone.
Now, i want DIY the installation. Coz i like DIY and wanna save my RM50. hehe....
So...anyone can help? plz...
- How to DIY it?
- How the rite steps go?
Thanx!!
