yes, that's the way....same as i did on my lock knob....:DOriginally posted by fstrader@Oct 18 2004, 23:32
just cut it by half. :D
Er... I think you got your forces all wrong bro.Originally posted by Joeker@Oct 19 2004, 01:00
The cutting and welding is not done on the gear stick.
THe cutting and welding is done on the fulcrum.
Eg. Did any of you played see-saw at the play ground.
If you sat nearer to the fulcrum, the distance you travel is shorter but the opposite side required more effort to push you up.
And if you sat further away from the fulcrum, the distance travelled is longer. However the effort is vice versa.
learn from mistakes laa bro .. :P :P ..Originally posted by Joeker@Oct 22 2004, 08:35
oppsss.....no wonder i flunked my fizik in SPM :P
UG PMOriginally posted by badguy@Oct 22 2004, 15:32
how much u want to sell??
RM100??
Similar threads | |
