Best engine to replace my 4A-FE in a AE111?
Shinda
12
New Zealand
Hi
i'm wondering what the best engine drop would be to do in my AE111 - easiest probibly the best, was thinking maybe of a 3S-GTE or something
Possibly just turbo charge my FE?
GRexer
GRexer™ KuzTomZ
1,199
10
Puchong
The Blacktop 4A-GE would be the best drop in. If i'm not mistaken, the 3S-GTE is not a direct fit.
Or, u can get a 4A-GZE and turbo-charge it(removing the supercharger)
rollakid
4,936
5
Kuching Sarawak
you'll get more answer if you post in Toyota Section. there are sifoos that rarely post outside toyota section.
anyway. 3sgte would be abit too big and heavy and will ruin the balance of the car. its not really a good choice unless you are after drag racing. AE111 is an FF layout car, thus having a heavy front end might make your car understeer all the time when you turn into the corner.
turbocharge your 4afe is another choice of course, there's people who is doing it. go for NA or Turbo is up to you. If you want turbo, most people in the toyota section probably suggest you get a 4agze and turbocharged it (sell the SC). OR, get a 6 speed blacktop halfcut from jdm ae111 and swap everything over.
i'm not very sure, but i heard that putting 3sgte inside AE chasis not only upset the balance, but also abit too tight. you basically can't do anything to it once the engine is in cuz there's just not enough space. imagine something gone wrong with the engine and you have to take the engine out to fix it.
just my 2 cent. cheers.
Shinda
12
New Zealand
after a turbo engine drop in i should mention.
kinda wanna go pppitsiiii
rollakid
4,936
5
Kuching Sarawak
then 4agze would be a nice choice for you. the block is strong and the stock internal is good all the way up to 300hp. you don't really need more than that cuz FF chasis like the corolla can't really use all those power anyway.
for lower boost go for the late generation gze cuz the comp ratio is higher at 8.9:1. good for normal driving cuz it still have some power when you are off the boost. for high boost then get the older piston at 8:1 comp ratio.
Shinda
12
New Zealand
thanks man i reposted in the toyota part
GRexer
GRexer™ KuzTomZ
1,199
10
Puchong
Yeah... the 4A-GZE would be a good idea if u are going for the turbo route, sell off the supercharger wouldn't be a hard thing to do. If not mistaken, earlier and later GZE's difference is in the engine management as well?
rollakid
4,936
5
Kuching Sarawak
yes, the earlier model runs on AFM, while the later 2 models run on MAP. regarding the later model, some say that the unit on the late model AE92 supercharge is better than the one in AE101. so far i can't prove anything, just what i heard.
huakenny
LB Performance
9,126
240
Kota Kinabalu
Black-top twincam 20valve.....automatic...with 5 speed....or manual wit 6 speeds.....
if wan powerful....4A-Gze lo...supercharger engine.....but i suggest blacktop...smoother...my 2 cent
Shinda
12
New Zealand
So huakenny u recommend the black top with turbo on it?
huakenny
LB Performance
9,126
240
Kota Kinabalu
if wan powerful.....put in supercharger engine n change to big pulley to gain more power.....the easiest way to increase power for supercharger.......
u add turbo only if u feels supercharger cant satisfy u...but i think supercharger itself if u mods it oledi fast enuf......my 2 cents
Shinda
12
New Zealand
Can someone tell me the difference between a 4A-FE and a 4A-GE other than a black top 20v engine
taking the pleasure to share with you
looking familiar - the black civic ...yupp....from car club TT - in my blog
10th July Free Detailing Workshop With KC & Seech...
