airtrek having temperature issue
4G93NAPower
119
8
Penang
i recall theres some way to by-pass the OEM temperature map for airtrek ECU to start the fans, but seems like the old forum had gone so sifus please help me with this.
kaninbu
669
104
1,543
bro,u mean mod the ecu setting to let the fan run fullspeed?actually the fan controller is just behind the fan.
nyantong
192
50
Rather than bypass, why not get a lower temperature fan switch?
4G93NAPower
119
8
Penang
how does the low temp fan switch looks like? is it universal?
the foreman say my fan controller kong d, now whenever i stop for too long (eg traffic jam) temperature start to climb @@
kaninbu
669
104
1,543
bro,u sure ur fan controller spoil?if fan not moving ur car will overheated within 10min after start ,nonit wait til traffic jam.
8229
118
6
Check the fan motor.. Maybe the motor not spin at the actual speed..
stutzedward
3,416
561
Yup, mine wasn't spoilt. It was more like not spinnning fast enough and sometimes, not spinning at all. WHen you knock it with a spanner, it will spin again. It's motor brush all eaten up la.. wish I can just change the brush like how I can change my 540 motors (RC'ers will know what is this :D)
qamarl
Jul 1, 2012
31
selangor
some said ...we need to change to performance thermostat (68 degree Celsius) to keep engine cool by allowing the coolant to flow through the engine sooner rather than standard thermostat. Anyone here know.... what the best performance thermostat for airtrek?
kaninbu
669
104
1,543
perdana thermostat open at 76'c n cost rm100++
sard,ntcl cost open at 68'c n cost rm300
all can fit without problem.
Yadado
23
7
3,003
Why don't mod to have the fan start spinning the moment you start car?
stutzedward
3,416
561
I guess I need to sort out my heating system too. When it's hot, it's retarding so badly that the car felt very sluggish and lack of power. I went to Ah Wah's place last Saturday. I'll need to get a 65c thermostart, a 85c fan controller (original only spins at 95c) and FMIC. All these aren't cheap though...
Lifting hood will certainly help but I am reluctant to do it. Don't like the gap while hood closed. Next alternative is to remove the rubber strip along the top of the firewall... that will help to expel heat when the car is moving.
4G93NAPower
119
8
Penang
the foreman say the fan controller going to spoil as it syok syok turn on and off the fan... will check whether the fan motor is in good condition or not
kaninbu
669
104
1,543
bro,ur fan syok syok when traffic jam + noon time off...very scary leh
darkcolt
16
1,503
stutzedward, wat is your current temp for your fan to activate? Is it 90c kick in to 85c stop or is it
85c kick in to 80 stop?
Wat is your highest water temp at stationary, without air-con, in sunny weather.
stutzedward
3,416
561
If I am not mistaken when Ah Wah checked last time, it starts the fan only at 90c. I do not have a temperature meter to measure that, Ah Wah used info-display to check.
dear sifuses,
my problem is, the starter wont stop working even when the engine already starts, even more surprisingly it's still working when I turned off the key. thought it was the relay problem, changed wit my horn relay still problem persist, spent a bit more & use a new 1 just making sure & stil same problem, it even burnt my jumper coz starter wont stop, luckily nothing severe happened, if the other car engine wasn't running bet it'll drain the batt 2. any thoughts @ this...
