Adjustables height
xatomic
91
I just changed to GAB hi-lo adjustables for Wira. As i m still a noob to all these adjustables, here are some of my concerns i hope you guys here can help to address.
1) Is there such thing as an optimum height? Does lower means more stability/better handling and tradeoff of comfort?
2) My right side is a bit lower than the left. Is this normal? I am running on 15" wheels, with around 2 fingers gap on the right and 3 fingers on the left.
starscream
147
IMO the height needs to be tune base on weight of your car, & the track if your looking for extreme accuracy usually races. But for malaysian road (badly uneven), i went up to 4 fingers for the front before & its still good in corners, now im 3 fingers necause 4 looks weird.not sure bout the 2 fingers gap on right & 3 fingers left, but does not look normal to me, it might not be bad i guess.
xatomic
91
the slight difference in the height exists even in stock springs and absorbers..i just thought because the driver side is on the right, it is more biased
starscream
147
i think 5K200 /4k300 means 5 kg spring rate, 200 length front & 4Kg with 300 length.
xatomic
91
Sorry, but can the hi-lo type set the spring rate? i thought only the height?
Edisonkim
112
that was a spring rate.. hehe! sorry for late reply .. anyway have fun when using adjustable hi~lo.. :)
dennisdreams
333
21
optimum working hight is where the spring was 1/2 way at it's relax length and fully compress length. and where the absorber's shaft should be at it's 3/5 way down (if the shaft is 5 inches when protruded, it should sit at about 2 inches(visible) when the car is fully rest on the spring.
xinghonh
1,415
7
borrow ur thread for a while ya
im using hotbits adjustables wid pillowball
the prob is...when i turn left/right...there is this tok tok tok sound...
when im driving on the straight road there is no sound..
it happened once i adjusted the height of the adjustables....y is this happening bros???
starscream
147
try taking out the pillow ball mount & replace with a original top mount & see if still got the sound.
xinghonh
1,415
7
okok will try that tmr
will this ruin my camber and alignment?
i remember the shop fella said he cant adjust the camber on my pillowball
Hey Guys,
As per the title. What are these new generation of Peugeots, Renaults, Citreons & Fiats like to live with in Malaysia? Anyone have any personal experience with a new gen frenchie/italian in Malaysia? Its always intriguing to me that these niche brands in Malaysia consistently pop-up in top car awards in Europe but are hardly acknowledged here.
With the prices they're going for these days in Malaysia, hard to deny how tempting it is to wanna take the leap and pickup a new 308 or...
