4G92P jerking
Also, will try with contact cleaner. I see in Ace, quite expensive, 1 bottle RM80++ huhu :hmmmm:
---------- Post added at 10:08 AM ---------- 6 hour anti-bump limit - Previous post was at 10:08 AM ----------
OK.. noted on that. Thanks
What? RM80 per can for contact cleaner. Should be around RM15 to 20 can get dy.....
avex00
Feb 12, 2013
12
Selangor
Ace sells all imported stuffs, went thru a few oceans to come over..price doubled and best is..Made in the USA, hoping its quality after pouring in wont kill yr car...LMAO
ACE mostly in shopping center, nice air con and environment for you to shop so all that is costed in. Just like that day I bought some fertilizer for a friend. At Aeon is like RM10 per kg but I got them at my hardware store at 4kg for RM20 only....
gunnerzz
Jul 3, 2014
2,109
695
713
38
Melaka
anyone in melaka can just borrow my contact cleaner.....then belanja me roti canai...kawtim..
so far i only used it twice after buying it.
jebatdex
430
18
518
Skudai, Johor
So far, what I did:
- replace plug cable
- replace fuel filter
- clean MAF using CRC MAF Cleaner
- replace distributor with half cut one
Now, the problem is; when I press the acceleration pedal abruptly, is will be bad jerking. After a few moment, it will be normal again. For example, going into SmartTag lane with gear 2, after the toll, start to accelerate, then jerking happened and back to normal after some time. If I want to avoid the jerking, need to accelerate/pick up speed very slowly, cannot be abruptly. Anyone has experienced this kind of problem? Maybe the halfcut distributor gives problem, but when I first installed it, no problem happened... :hmmmm::hmmmm::hmmmm:
My Mitsu Galant V6 viento's door seals are rotting away, and that allows rainwater to enter the cabin. Its kinda hard to find replacement seals as the car is pretty rare, and the perdana's ones dont fit. Can any one with experience guide me on how to fix this? Perhaps some universal door seals which i can use?
Rotten door seals :
Car model (not actual car) ...
