Help regarding Gen2 Brakes Upgrade
dmaul
45
Hi to all the sifus around,
Just seeking for opinion and looking around, just wondering if there's any Gen2 around that has successfully upgraded to a set of Brembo brakes, and if yes, what are the modifications that have to be done and which Brembo (from which car) do u guys use??
Or alternatively, what other good brakes that have been upgraded into a Gen2? For those twinpots from Evo3/4, any modifications that have to be done? Or just plug and play?
Thanks for your feedbacks in advance! XD
dmaul
45
Gen2 Brakes Upgrade
TitanRev
You think I print money?
Mar 3, 2005
8,180
3,678
Dear Forummer, please post only 1 thread of the same title. Do not post the same thread in 2 different section. Thank You..
dmaul
45
Any PnP brakes upgrade out there for Gen2?? Anyone modded?? :confused:
xtremeleo
3,247
464
5,183
what engine are u using now? fyi, the brake system u have now is sufficient for the car, the trick is choosing the right pads.. i trust bendix for the job
dmaul
45
get the braking system from evo4.
Thanks, but will it be PnP or need to mod??
Hmm, going to up the power soon, so thinking of getting something better, thanks!! =D
xtremeleo
3,247
464
5,183
what mods are gonna get? fyi, iam still with the std caliper n uprated pads, pushing 186hp. my fren, evo3 pushing 360hp on dyno dynamics, again still wit std caliper but wit uprated pads. dat evo accelerates from stand still to a hundred in under 5secs, and still be able to stop in time.
so, how much power are u aiming at anyway? brembos are overrated if u r only looking at a mere 200hp
artworkz
706
119
JB
i think evo brembo or evo 4 twin pot canot pnp. must change knuckle as well. correct me if i m wrong
---------- Post added at 02:34 PM ---------- 6 hour anti-bump limit - Previous post was at 02:19 PM ----------
of u can take pnp APracing from s.neo lotus
dmaul
45
Tyvm for ur suggestions.. just thinkin of bot onli.. hehe... but glamour see other caliper... hahah.. anyway, they're too exp too i guess... thanks again! anyway, do u know if there's ebc green stuff for gen2??
Wonderful.. APracing from neo... wait ppl go crash their new car send to chop shop 1st!!! LOL
xtremeleo
3,247
464
5,183
for the green stuff, u have to contact their dealers sir, ive never bought them for several reasons, 1. they are indeed expensive 2. i can get sumthing as good if not better for lower price 3. easier to get other pads.
AP Racing from the neo? good luck, hehe
SimpleGuy
751
If wanna upgrade brake, u can try choose from cheap 4pot brake like from skyline R32, it is not bad for the start, since it is only around RM500, but custom make a bracket cost u near to the brake itself. My own experience from single pot to 4pots different is... single pot tend to jam brake more easily, 4pots lesser chance to jam brake except u press it real hard, mayb deal to 4pot brakepad touch the rotor more even... If u wanna upgrade rear to 2/4pots too, then it really cost u a bomb ^_^
dmaul
45
Alright, thx mate.. XD
Lemme guess, u running R32 brakes in ur car bro?? :biggrin: anyway, pcd will run??
artworkz
706
119
JB
of course is 4x114.3
have ppl intro to me fix nissan 4 pot. the center bore of disc need enlarge 5mm den need drill another 3 hole.
but due to need custom bracet to hold caliper, i was reject this purpose. brake is serious part, if sudden bracet failure due to high temp or stress.....i cant imagine.
in skudai, jb.ppl quote me rm700 after trade in GSR brake 2years ago include fix.
artworkz
706
119
JB
yah, saw ppl change ck model gsr engine. need to change knucle as well to install gsr brake. but i dunno need change lower arm or not.
SimpleGuy
751
In Gen2 there is no alternate brake to upgrade without a bracket, so bracket is a real nid for any brake other than OEM ^_^ Dun worry abt the bracket will break lah, jz dun machine the bracket too thin then won't cause u any danger. Some bracket break is bcoz they more to beauty, they make it thin but using cheap quality steel. Anyway, a good machine shop will always get u a good end product. Dmaul, If wan a better 4pot, u can use GTO 4pot, the disc is bigger, but u nid 17" Rim.
dmaul
45
so wat brakes u using now bro?? u gen2 user too right?? mind to share?? XD
i too found out recently that Option from taiwan has pnp brakes for gen2, so does D&D and Grippen... But all those need around rm3k - 4k+.... hahah..
Hi Mod sifus... Just want to ask your opinion on this...
I have a wira 1.6 Aeroback with Promote Bumper... Currently using APM Sport Springs but it is too low...
So was wondering if changing to Eibach Prokit would it solve the issue above? I know the comfort would be much better...
Or changing to Adjustables a better option? You get the height and comfort? The other day I went to Kakimotor.com and they recommend me to get HWL, and claim it can be as comfortable as Eibach... is this...
