Nicely done Skywalker.. Mind asking what LEDs are you using. Haven't really taken out my dashboard's meter to see what bulb is the meter using. Is it t5, t10 . Does it necessary needs the rare t4.2?nice or not??...
t10 LEDNicely done Skywalker.. Mind asking what LEDs are you using. Haven't really taken out my dashboard's meter to see what bulb is the meter using. Is it t5, t10 . Does it necessary needs the rare t4.2?
so freaking bright man!!!nice or not??...
must use high farks LED mah... normal LED where got bright enough...so freaking bright man!!!
---------- Post added at 12:39 AM ---------- 6 hour anti-bump limit - Previous post was at 12:38 AM ----------
do you guys know mitsubishi lancer dashboard meter panel use what LED?
coz my ride color very dim...
confirm normal T10 bulb?must use high farks LED mah... normal LED where got bright enough...
mitsu lancer meter should be using similar T10 bulb...
dismantle out the meter 1sthi need help
newbie ya ... using mivec dashboard with 4g92 meter manual now is yellow wish colour i wanted to change to blue can tell me wat size and how much is the bulb ??
and wat do i need to do step by step pls T.T..... and do i need to take out the meter needle ??
