easymustard
37
but i thought vdo are self learning ecu?
however maybe tofu is correct, spend your monies on something else first, maybe not on clutch...
K&N open pod should be in the region of RM320 without the ram pipe
ram pipe normally cost around RM60-70 depending on quality!
yah dont speed so fast on kota bahru roads, small kids run across the road like nobody's business:thefinger:
lol im just speeding 10pm and above so no kids are allowed on the road.well i oredi ask my pomen, he said changing clutch alone wont give a lot of change.just a lil bit more pickup.and,too hard to find K&N open pod here maa,i just found simota and HKS only.
joev8796
145
tat exedy semi racing cluth is not made in japan, just local exedy make it for proton 4g1x. if i were u, i'l go 4 BR cluth which u can find it at da maketplace. bout da filter, better go for k&n as they provide million mile warranty if u reg urs online. hks i heard from some ppl tat it is powerful thn oth but let big amount of dirt pass through.
Bump:
afmarsyal
100
6
i'm having this problem too... i cannot retard too much or else have bad throttle response.... engine feels jerky at partial throttle...
hmm, can air fuel regulator can solve this? if can looking forward to install..
ettm_14
605
81
i can get k&N and maybe pass to you on my way up to kota bahru...if thats what you really want, i dont really recommend HHKS eventhough they got a nice growl to it!
biz-da-tech
520
exedy clutch some said got made in japan and some said is not ... which is true also dunno.
all i just found out there have 2 type. one is red color , that clutch plate is only have 4 spring. and the silver chrome color have 6 spring?
and some people said only have 1 type?
ahh confuse wht the hell? :X:smokin:
ettm_14
605
81
sky, what is the normal price for a fuel regulator, a ok but not so expensive like works or sard?without meter have to tune by try and error?
blind_lan
33
i got 2 Q
How to advance ignition or firing with SVDO???
SVDO can Piggyback??
fstr
7,935
954
Sahara Desert
siemens based ecu engines cant advance their ignition/firing cos the distributor cant move at all.
unless u opt for adj cam pulley, but for this u can advance/retard ur camshafts only.
easymustard
37
thx.maybe if i dont have time to go to KL, i order from u lol.always go to KL but just for meeting,damn!
btw,if i wanna change my siemen ECU, what brand is suitable?and how much it cost?
afmarsyal
100
6
siemens ecu wanna change? damage or for the sake of more power? if damage and going for more power and tuneability change to mmc ecu with complete wiring, then piggyback it..cost should be rm1400-1600, exclusive piggyback unit..piggyback greddy emanage blue can get for about rm1500 inclusive tuning..or can oso change the ecu unit with performance one like haltech or motec..but for na and cc only 1.5 non vtec i'm not sure if any sifoo here would recommend..not much gain but cost very much..can go up to rm6000 per unit..try work with hardware first, and when the software cannot support then upgrade the ecu..but however, if the ecu not damage, why not try find sifu khguan and ask him how to mod your engine..he has a project car running on siemens ecu..maybe then you not need to change the ecu afterall..
for clutch plate, why not try lightened 1.6 supertouring flywheel complete with 7.5 inch clutch? pickup much2 better..and not so hard to press like racing clutch..
hi brother's,
need some advise on a stock evo 3 engine.my bro had just converted his perdana engine to a evo 3 engine.the thing is wat are the parts to be changed or install to get atleast 1.5 bar without effecting the engine with a minimal cost.tis is becoz his mechanic told him that on a stock engine if we set the boost to 1.5 bar is dangerous to the engine.is it true n plzz advise in this matter.your advise is much appreciated.thank u brothers.....:confused:
