Performance spark plug cable
BLANk
1,750
6,757
Sardine
www.zerotohundred.com
bro,please do some research before u ask... the engine doesn't use spark plug cable...it use direct coil pack...
limking
43
6
1,508
:listen:Just check out the Okada Plasma Coil or Nology Hotwires with coil on cables .These 2 are very good ones ,can really feel the power once fitted .I should know coz' mine using Hotwires .:biggrin:
limking
43
6
1,508
Thanks limking, but where can i get this Okada Plasma Coil or Nology Hotwires ?
For Nology Hotwire you can check out JC Asia Motosports at Bandar Sunway .Tel no : 03-56338529 / 0122113612 : Jacky
For Okada Plasma Coil you can check out Exotic Mod at Sunway Damansara Industrial Park . Tel no : 03-78033938 / 0173780028
Good luck !:biggrin:
Let us know the outcome after you have it fix .Wanna see whether your experience in the car is the same like mine or not.
surin0923
4
Thanks for the information limking,But bro i've already called up JC Asia Motosports & Exotic Mod, but they dunt have the cables for Nissan Serena.... Do you know any other dealer?
limking
43
6
1,508
Will check out for you later on .Perhap meanwhile if you don't mind S'pore then you can check out www.k-techauto.com .Guy by the name of Peter is in charge contact no : +6598235362 :biggrin:
limking
43
6
1,508
surin ,for the Okada one you could try N1 Racing ,contact no : 03-56365557 .Ain't sure whether do they have Nology as well but am very certain that they (N1 Racing) do have Okada Project Plasma Direct Ignition Coils on their shelf.Hope that they do have your ride specs.
Good luck.:wavey:
Just a problem .. i notice that the myvi eagle eye projetor that cames with that decoration led ...
I just realize that,the led decoration works on the right lampside but not on the left lampside ..
after that, some check up with some car accersories shop,now the right lampside decoration led not
work,but the left lampside decoration led starts to work.
Im,in a headache now.
Ackward, moments begin to happen after change the car battery ...:(
Actually i thought,the...
