afmarsyal
100
6
hahaha..tofu sifu..good question..i once called the powerzone people..quite long time ago asking about installing stroker kit and hi cam price quotation..the person receive my call state that, 'yes u can but u onli can get about 1.4cc..'
i think the mech who gave me info on 1.3 and 1.5 block came out from same mould have logical explanation..proton, or even mitsubishi won't spend precious money to develope each engine part to suit specific part only..to reduce production cost, better produce interchangeable part and rebore or lathe to size..from thorough observation, 1.3 block sleeve or slit (sarung blok..alaa..the one you can replace by reboring and refitting at engineering wshop when you run out of piston size..i really don't know the specific term for it.. :P) is a lot thicker than 1.5..cost effective solution..but this mech is under the tree old school one..i'm not sure but the explanation really makes sense..
sifu guan aaa..i did it plus internal 1.5 items (pistons and rings) plus labour + lubes rm6++ onli..to be exact, rm670.00..but that varies on how much internal parts can be salvage and use back..i don't change everything..even the conrod and a lot of bearings i use back..during that time not enough money to change everything new :P..emergency maintenance..
owh, by the way, i asked eon service padang lalang kuantan about the price for a 1.5 block..the mech said rm400 a piece..is it true? is it a new one or halfcut? not enough time to clarify on that with the mech.. :P
p/s : haxdumm..sifu tofu correct maa..buy veyron lor..
tofu_manic
1,342
91
5,148
honestly im not too sure about this myself..bout what the powerzone guy sed, it doesnt make any sense that if the stroker kit is placed into a 4g13, u will only get 1400cc (not 1.4cc la :P)...since the bore and stroke is the same, 76 x 87.3 no matter what will yield close to 1600cc....UNLESS they were somehow talking about using the 4g18 crank matched with some other type of short pistons...did they clarify? whether it was just using the crank? or the complete kit with a 4g13?
yeah, i understand what ur mech is saying, i do think about that as well...dimensions all the same, intake/exhaust port all the same, haih....shud have calculated the wall thickness the other day, darn
afmarsyal
100
6
tofu sifu, that day when i asked powerzone guy, my engine still 1.3..i asked them because i'm really annoyed with power delivery of 1.3 engine..i'm a common user of jalan genting sempah to batang kali from kuantan enroute to taiping..so when i asked the powerzone, i believe that guy is thinking, bore x stroke is 71 x 87.3 la kot..that's why the guy said 1.4..hehehehe :)
tofu_manic
1,342
91
5,148
ori 4g13 piston wont fit with the longer stroke crank under the engine head, as the piston is too long, if u notice, the 4g18 piston is really short
oh well....hopefully someone out there can use their calipers and start calculating lol
i will loiter around the local workshop here, and try look see look see a bit
jswong
209
9
3,018
yes.. the ECU will adjust the duty cycle accordingly to get the proper a/f ratio.
mechanics do not know the power of SVDO... and most of them do not know how to deal with it... cos everything seems cannot tune... so that's y they say no good.. in fact SVDO ecu is a very powerful ECU... it can take or compensate a many small engine defects and tune the engine to run on the best stock settings.. unless the parameters are off the limits.. then u will see the check engine light..
like my car MMC, the moment i started the engine after the rebuild.. the mapping are all not right... i'm getting black smoke at the exhaust and no power at all... need to perform PDT tuning in order to get the engine running smoothly... on SVDO.. the engine just start smoothly without any electronic tuning at all... i was quite amazed that time when i started the car...
so it is up to u to judge which is better.... well for me.. i think both have their strengths and weaknesses... MMC have the flexibility to do more tuning capabilites like the ignition timing and able to fit in a piggyback for further tuning.
This is very true, people are just parroting that "MMC is better than SVDO" just because MMC is dumb enough to be fooled by a piggyback while SVDO isn't. However, SVDO for Proton cars (EMS 400 series?) isn't a full closed-loop ECU system, it's only closed loop until 3500 rpm. After that it functions in open-loop mode.
Powerzone uses the Power Commander lambda sensor piggyback for SVDO ECU for lambda value modification. Not sure whether Power Commander can configure for an open-loop cutover rev point and switch over to MAP/MAF value modification. For semi closed-loop ECU systems like SVDO, the only sort of piggyback that'll work is one that combines the functions of a lambda sensor piggyback and a regular MAP/MAF piggyback, with the ability to define the closed/open loop cutover zone.
HaxDuum
142
wan to know more ma, so can put items into my wish list...chill dude
afmarsyal
100
6
ooo...i see..never saw the stroker kit in person..just gave a call to the shop only..but from sifu tofu statement, i got a bit confused here..i thought 1.5 piston and 1.3 piston same length..those 2 piston i have seen in person..one is quite small, one is bigger..but standing same height..is it the powerzone rebore and refit 4g18 piston as well for the stroker kit installation? from the advertisement, i did see pistons come as part of the package..if so, block 1.3 oso can la..but need to further rebore and fit the 4g18 piston..maybe comes with additional cost? after all, 71mm to 75.5mm can, why 75.5mm to 76mm cannot..just a little bit more to rebore..i did see the block sleeve is about 2mm thick after rebore to 75.5mm
however i still stumble upon some mech, that claims 4g13 block and 1.5 block not the same..this mech claims to be regular participants in jempol drag battle.. :P pening oredi..why not someone try to fool the powerzone people by sending a 1.3 block rebore to 1.5 and put in the 1.6 stroker kit in..if can fit, my under the tree old school mech is right..if can't, so 1.3 block and 1.5 block is different..the problem is, the engine number and displacement is engrave to the block, some mech look at it only immediately say cannot.. :P reason is, the block is weaker than 1.5..surely la will get that answer..
so my next project is to install this stroker kit..i still dunno when yet because i think my current setup is fun oredi..but still, untill this 1.3 to 1.5 thingy not proven, i'm restless..arghh
tofu_manic
1,342
91
5,148
chill memang chill...just that it is difficult to give suggestions when u dont state a budget, as u asked about what u shud do since u are overhauling the engine edi... :confused:
and the answer to some stuffs u asked about are in this thread i think, do read the thread dude, some good info in there, can start compiling the list from there
yes, pistons are part of the stroker kit....still....i dont understand why powerzone sez it is only for 4g15, im sure they would like the potential market for the stroker kit to be bigger, not smaller rite....still i wish someone could clarify this, haih....if not many ppl will upgrade to the 4g15 block for no reason....
i too am restless hehe, question marks popping left and right
khguan
4,818
26
Seri Kembangan
fotopic.net
the reason ppl say 1.3 block cant fit in 1.6 stroker or cant stroke to 1.5 is bcos of the cylinder liner not enough "meat" to be bored. I always hear this... but still got ppl do it... so i guess reliability is the issue here lo..
tofu_manic
1,342
91
5,148
then again...the 4g13 intake / exhaust lines up perfectly the same as the 4g15 block, with outer dimensions being the same...
imagine...if both blocks have not been bored...being just a solid engine block with no holes...then wont this mean that they are identical? then suddenly u bore one block....with a 71mm hole....the other one with a 76mm hole....isnt this the case we are seeing now
the crank, conrods share the same position....so the Center of each 4g13/15 pistons' locations should be exactly the same as well...so distance between the 4g13/15 piston Center should be the same...then by right....whatever u can throw into the 4g15 block....shudnt it be the same with the 4g13 as well?
so whaddya think...anything flawed in the reasons above? im not too sure myself
afmarsyal
100
6
yes..if you can see, 1.5 block has very thin wall surrounding the piston compare to 1.5..if don't believe, open one 1.3 block..i remember one posting here showing a standard 1.5 block..from sifu guan i think, regarding modifying a siemens ecu 4g15p..the pistons seemed super big..but it's standard..well in 1.3 block, the pistons didn't seemed that big..
biz-da-tech
520
tofu miniac - u do post a topic upgrade stocker kit for 4g13p at marketplace ?
the guy i have call and he said that is stock piston 1.5,conrod ,crank shaft,oil pum.
and no need to do anything to 4g13 engine just plug and play???
well i dont know why.
but i ask my mech said 4g13 block cannot fit 4g15 piston...
may someone tell me the price fit in all those stock 4g15 stucker kit into 4g13p are really need how much money?
but as i know the powerzone stucker kit is very expensive .. like not worth the money :P.
but i did asked before like 1 years before someone said powerzone stroker kit is for 4g13p and plug and play too...?
HaxDuum
i stay in Penang :p
but i think my Vdesign not same like others but a few parts sure same. LOl or else i dunno. for penang im the 1st Vdesign different from others.
if u penang sure we need come out yum cha
tofu_manic
1,342
91
5,148
yea...only thing left is for someone with calipers to measure hehe
not stucker, StrokeR hehe
anyways, the 4g13 shares the same conrods, and crankshaft as the 4g15, so dont bother getting an identical crank and conrods from the fella, when u have them already...only the 4g15 pistons are different
1600cc stroker kit is expensive, but good stuff...u wanna get easy power just stuff in the 4g15 pistons, and ure done, instant 1468cc
My dad who drives a BMW E34 520 with a 525 engine bought the car in a very immaculate condition but the paint was hacked! Ive been wanted to detail it for some time but i know black is the worst colour to be detailed. As a beginner i took it as a lesson and training , as long i didnt burn the paint right? =p
SO i just took up the Front Bonnet as a test session for a black colour so that i could learn from my mistakes.
not forgetting the steps that KC taught me, just gives me a peace of...
