4g92p upgrades
oligokoko
99
Hie zth mod'ers,
I just bought a satria 1.6 A n wanted to upgrade it abit. just a few ques here. more ques as time passes by. hehe
1. my tb kong oredi. looking 2 buy a new tb. just wondering, is d perdana v6 tb suitable to d engine? is it PnP? any mods required?
2. Currently have d stock std 14" rims + kyb gas + stock springs. d height is about 4 fingers. wanted 2 go for sports spring but dun know which brand to go for n how low will d car be when fitted. care to advice? i will change my rims to 15" nxt month.
3. bubbles growing up on my roof, damn. anybody have replaced d roof b4? care to tell me d price. need to budget 1st. hehehe
4. thinkin 2 spray my satria matte black or black. which will look better? any suggestions/advices?
think this is all 4 now. d ques will come as time passes by. really3 appriciate any of ur opinions
zac
1,347
231
Johor Bahru
budget for the spring?? i used sport spring before but the handling and comfort level, nowadays adjustable is quite cheap, why dun try it out?
Matte black is cool, but also depend on your bodykit, my car is original look so din try out fancy paint.
oligokoko
99
budget mayb around rm300+ abit. hehehe. wut brand do u recommend? i heard tht GAB is quite stiff
JackWaiKit
262
5
www.friendster.com
It's doesn't relevant with the stiffness...
Of course a bit but stiff more on asb...
U kyb gas defenately will be stiffer than hydraulic but better cornering
GAB sport spring will bout RM650 if i'm not mistaken. front & rear...300 better look for used...
no idea can change what TB...
But most probably, 4G9x series will be fit to each others
15" sport rim will still can fit 3 or 2 finger unless u lowered.
with lowered, ur sport spring can't affort...how bout during u across the bump...
u can't even go up the up floor car park...
oligokoko
99
tq 4 all of ur responds
For the TB, you can use the Perdana Sei TB plug and play
yup2. looking for it 2 replace my kong tb. perdana v6 1 can plug n play oso ka? sumbody offered me d v6 tb but im not so sure tht it can plug n play
ooo ok. so tht means tht i shouldnt change 2 sport springs is it?
ART///SPEED
287
upgrade to v6 tb for more response but you have to change the auto choke socket
achmedrauff
255
5
www.onlyinmalaysiamah.com
bubbles on roof~ you cant possibly replace your roof~ but restoration can be done. The paint shop should be able to do that for your. Painting~ just put aside RM2k should be enough.
hafiz4g91
30
1,508
i want to share my experience here about gab adjustable.
b4 i used gab, i used apm adjustable. pergh!!!! keras mcm nk gler. then i change to to gab but the seller tell me to change the spring to 5k400 insted of std gab for wira is 5k200. this is because he said my engine(4g91) is heavy. after a yr i feel not comfortable. i asked many ppl experience in this and found 1 w/shop doing this n they recommend me to "kacuk" with eg spring. and my ride now more comfortable n still can take corner at 120km/j lo.
now the price still cheap. around 1k to 1.7k only. serviceable is more important.
Mar 1, 2009
Satria is a small car, if you spray it matte black or black it will even look smaller. Satria do not have the shape say Mit. Evo 9, or Subaru STi ver9. These cars will look fabulous in matte black couple with custome stickers wrap all round. So stick to your color, and try to get a nice body kit and look also at stickers.
Your roof if you want a more permanent repair that last-better change it. Cost around 1.5-1.8K with painting. Don't believe in fiberglass or anyone who claim that they can give you a cheap repair. It WON'T work. CHANGING THE ROOF is the ONLY solution.
JackWaiKit
262
5
www.friendster.com
no really...but RM300 very diff.
U can refer to hafiz4G91...coz i'm using adjustable...1 time deal mah!!!
But very stiff lah...
See if u change to harder or lower spring, ur asb will also being compress...
When asb being compress, the travel level of the sub will be shorter...
It's mean will also be more stiff...
by that time, u still suffer with bump, multi level carpark,& unstable cornering...
This is just my frenz experience!!!
oligokoko
99
ohh ok. thx 4 d opinion. sumhow kyb gas + OEM springs feels fine with me. just thinkin bout d springs coz i want my car to be lower abit. but after discussin, i will rethink again. thank u jack. btw, wut adjustable r u using?
JackWaiKit
262
5
www.friendster.com
D2 hi/lo soft/hard...with pillow ball
BTW,
U r welcome...
Try to ask some others ppl exp...
But bware of the spring rate...
Hmmmm...idon't know how to explain bout it...
just give u an example- u can use evo ori asb...soft but handling no bad
but evo engine is more heavier...so once u installed ur ride will looks higher
oligokoko
99
BTW,
U r welcome...
ohh, i get it. yesterday i rode wif my friend on his myvi wif sport spring. cornering is damn gud but on straight road, its like riding a horse. d car looks nice, not too lowered. now i must really2 consider this carefully. thinkin bout adjustable oso but alot of things need to b done lah especially d bubble on roof. scared 1 day d roof will collapse. hehehe
keithmin
95
ohh, means normal springs r better in bumps n straight roads n sports springs r better in cornerings...hmmm...now i understand
JackWaiKit
262
5
www.friendster.com
Agree with skywalker...
Spring will give u more stability...
But normal asb will drift u out...!!!
The reason that u feel goo cornering is bcoz of hard spring rate...
but when it achieve the maximum practical your driving skills, u may need harder spring...
U will feel still not statisfy!
In this time frame, u may under steer...
So adj asb can let u adj the damper...
Higher damper will coz shorter absorb...means more stiff!!!
but will solve the under steer problem...
keithmin
95
lol, i always go up to Genting, coz i usually send things up there...currently im using normal springs, its higher than sport springs, n i know sport springs compress lesser than normal springs
i feel that my car like gonna throw in high speed cornering, so if i changed to sport springs, it should be better rite ?
While the Ferrari California is often viewed as the baby of the Maranello stables, it still packs quite a punch under its hood. Still, if you find the weight of the folding hardtop holding back the car from blowing wind in your hair, the folks at Anderson Germany have some tricks up their sleeves for you.
Under the hood, the 4.3-liter V8 gets an...
