How to improve? Slight power-loss after turning on air-cond...
KGhee
25
1,503
Any idea on what can be done to minimize power-loss after turning on the air-conditioning? I have asked my mechanic to adjust the timing so the engine rev higher during idle, but that is only a temporary solution. Currently driving a s-gti.
Appreciate the feedback.
jeffayn
621
62
3,028
Klang
the aircond need power to operate, how u wan to compensate the losses ?
if u want to compensate, you need to add more power la...:biggrin:
khoyos
2,633
156
5,163
Shah Alam
easy. when u switch on aircon, drive in relax mood. when ur in the mood for spirited driving, switch off aircon. will increase lifespan of aircon compressor.
SkYwAlKeR
Over 10,000 RPM!
10,146
300
5,183
ePoh ~ malacca
- remove ur aircond unit all together and fix a fan inside the cabin
- switch off ur aircond when u wants to do spirited drive
- use undersize lightweight pulley for ur compressor (this one hard to find, side effect u have a less cool aircond)
- service ur aircond compressor regularly
mivec_mivec
275
yup..agree with sifu sky..use smaller crank pulley..it may cost to belt as well..less cool but gain more power to engine.
KGhee
25
1,503
Thanks for the advice, as of now...definitely switching off my air-cond for spirited driving...haha. Can only do this at night, harder in the afternoon due to M'sian weather.
khoyos
2,633
156
5,163
Shah Alam
plus with all the traffic in the afternoon... better save ur petrol hehehe
clanzkiller
1,394
27
1,648
aiya air-con is when u got chicks inside your car..drive slowly and gentlely...don chok her until she don dare to sit on your car next time..plus u got more time to spend wit her inside your car...
when u're alone, just don use air con and play til u siok lo...
tat is how my usage of the air-con LOL...except raining day la,sure need air-con even if alone
alangbudi
144
Hahah totally agree with what clanzkiller said. Simple mechanism, on and off....
Shinjite
864
120
Klang
yup normally if its very hot then I will on my aircond and drive slowly because car powerless adi
my compressor is absorbing a huge load from my engine when its on......
renxun
1,138
37
1,648
if the car is fitted with a 2 way lsd.. hmm.... chicks will say..--ui ui wat happen to your car..? apa bunyi itu...? pandai tercabut ka..?
then u answer... - there is only one way to drive to ensure there is no sound....
chiiiih...!!.... haazz..~~ hazzz...hazzz.... kechiuu.....!:biggrin::thefinger:
clanzkiller
1,394
27
1,648
if the car is fitted with a 2 way lsd.. Hmm.... Chicks will say..--ui ui wat happen to your car..? Apa bunyi itu...? Pandai tercabut ka..?
Then u answer... - there is only one way to drive to ensure there is no sound....
Chiiiih...!!.... Haazz..~~ hazzz...hazzz.... Kechiuu.....!:biggrin::thefinger:
muahahahahah...
SkYwAlKeR
Over 10,000 RPM!
10,146
300
5,183
ePoh ~ malacca
ummmm.. why not to try use FICD?
ficd is to stabilize ur rpm when aircond switched on... it doesnt remove the parasitic power loss....
A Post Every 5 Mins
guys, whats the stock standard cam angle measurement for 4g91,92 and 93? any one knows..i tried searching all over the web, dissapointing..thanks guys..
