hks sqv2 problem
advinlkm
132
who using hks sqv2 blow off valve?got problem or not?when i fix to my 6a12tt when on air cond than test drive using gear number 1 than release back to natural the enjin will die off...u gut got this problem?my friend say is the sqv blow off valve problem coz the brand new hks sqv2 no adjustment....
Cow
1,090
advinlkm,
i think you can overcome this problem by adjusting your idling. set it higher
clanzkiller
1,394
27
1,648
zzzzz..
u try it without aircon first...
turbocharge car which cause enjin shut down automatically wit aircon and w/o aircon can be influence by lot of things...
unless u bought the imitate/replica hks sqv2 then sorry to tel u, lot of imitation sqv products having air leakage problem after 1-2 times boost..but if u're lucky then the BOV wil work like ORI BOV...
the car no need move also can test your bov..but if u wan it move also it's up to u..
and how many bar u boosting?
raja_emeperor
741
28
go an sell off your ssqv2, then go and find ssqv. if your prob start to happened after u install the ssqv2 then its that damn thing fault bcos no adjuster on it.
jinkl
4,624
376
3,183
clanzkiller
1,394
27
1,648
i used the specify bov for 1 years..no problem so far as max boost on 1.5bar...
brother
87,094
18
5,138
cheras,kl
zzzzz..
clanzkiller.....now day alot of imitation part is same like ori part ady.i also got sell the imitation ssqv2 so far i sell many dun have any complain from my customer for boost leakage.....but the imitation cant sustain high boost only.
clanzkiller
1,394
27
1,648
the quality of current imitation sqv2 products i dunno d..i only knew tat last time i bought 2 ssqv,the old model which can adjust one and it is imitate...then 2 also useless one...
diff imitation country produce diff quality of production..so maybe yours is cannot sustain high boost but tahan lasak, but others all also don have..or can sustain high boost but leaking?don think got such thing
ps : i'm not pointing to everyone who selling imitation products regarding tis...i'm just telling the facts for me...and hope ppl can make comparision btw genuine n imitate products..i believe there are good imitate products out there...but for me i don dare to try it anymore :D
brother
87,094
18
5,138
cheras,kl
hahahhah...... imitation and ori sure got diferent if u have money buy ori more better.heehe
mobb
393
im using ssqv imitation for almost one and a half year oredy
boosting 1 bar on e3
never got problem or any leakage so far... :)
Joeker
Walking Dead
3,580
62
Jinjang
Blow off valves (Atmospheric) causes problem because sudden drop in air pressure resulting in the air sensor meter to flood the combustion chamber with fuel (ECU reads WOT at O pressure).
To solve this, increase BOV spring rate (less opening, less drop in pressure) or use recirculate type blow off Valves.
Hi to everyone.
Exhaust Gas Recurculation (EGR) is actually a small valve that recirculate a small amount of exhaust gas back into the intake manifold.
They were designed for that because some ppl claims that by sending warmer gas into the combustion chamber, the air/fuel mix does not have to do as much work to heat up, and your engine runs more efficiently or even has a cooling effect on combustion temperatures that helps reduce the formation of oxides of nitrogen.
Ok my...
