How to install a volt meter
cacin
1,000
5
5,138
I thought the installation manual comes with the product?
Which voltmeter are you using? Brand? How many wires from the voltmeter?
cacin
1,000
5
5,138
If there are 5 wires total. 2 red, 2 black and 1 orange.
the thicker red should be connected to your battery (use fuse for protection). The thicker black to ground.
The thinner red also to battery with fuse protection. The thinner black to ground too.
The orange is to your headlight switch. So the lights on your meter turns one with the headlight.
Please correct me if I'm wrong.
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
whoa... voltmeter also got so many wire ahh??...
ken12292703
Drives a shopping cart...
1,542
5,138
SoMeWhErE
to know ur voltage reading la...when i high or low...:smokin:just if u like to do mr.boombastic into ur car......
Whao, thanks for the information. Why i starting not high de? 8V niaa~
Then walk walk very high~ 13.5V
Then on air cond not high already~ 12.5V
On lights cut stim~ 12V only :banghead:
On ICE can sleep~ 11.5V :banghead:
cacin
1,000
5
5,138
Sifu sky,
Basic voltmeter is 2 cable only. The other 3 cable is for those with black face (leds). One power for the led/light the other for ground. The orange one I guess to turn on or dim the meter at night. :)
That's based on the autogauge I have la, other meter might differ.
cacin
1,000
5
5,138
Is your battery still ok?
I think the moment you turn the key to ACC or ON (dont start car), battery should be around 12V.
JINEIL2EN
Over 10,000 RPM!
15,317
525
Island Of Pearl
team99ers.2.forumer.com
mine is 14.5, on all the lights & aircond, 14.3.
last time 15.3 le...:hmmmm: dunno why drop liao...mayb i unplug the grounding & vs...?:hmmmm:
wsonny
467
14
5,018
Ampang
i manage to install myself, the thick red i connect to the ciggry lighter another red i attach wit my boost meter. The both black also the same attach wit my boost meter wires. So far ok but don know cun or not.
ken12292703
1,542
5,138
SoMeWhErE
Cool..
I think something might be wrong with my alternator or battery. Prepare for a dead battery :mad:
OK, I decide to remove the air box and just go with an open pod. The longer pipe really boost low RPM torque while retaining high end flow. Have yet to insulate the pipe so it gets hot. Going to get some ceramic fiber wrap to insulate it.
I have remove the fog lamp and the hole is used for the air intake for the open pod.
