Siemens VS MMC
ettm_14
605
81
Sifoos arnd need assistance,
What are the major difference/s if I do change my siemens ECu to a MMC ECU on my 4G15??
I have one MMC injector kit in hand-if the difference not going to be alot different then it would not be worthwhile changing?
PLease enlighten me as I am new to ECU and stuffs like these!
Thanks
YuHaNiSa
195
before this i use satria 1.3 siemens vdo..i do basic performance + some recepy from my friend...0-100kmh 8sec and 0-400m 16sec
YuHaNiSa
195
so why wanna change the wiring + ecu mmc ? mmc injector are the same with siemens injector...
siemens vdo kind da like auto learn from what you mod...
siemens vdo have batter fc too my satria 1.3 rm10 can go 100kmh,also my friend car 4g15 siemens...
siemens vdo is free maintenance tuning or setting..
my friend wira 4G15 siemens with basic mod can beat gti pick-up and top speed..so so so
my 1.3 can do 190kmh
my friend 1.5 can do 200kmh
RedD
644
3,018
anywhere..
bro, wat a great mod/recipe u gt for ur 1.3 man.. btw, mind share?:_:
mine can onli go 140kph n the pick-up... zzZZzzzz... cant think of wat to do... :confused_smile:
Joeker
Walking Dead
3,580
62
Jinjang
Changing to MMC from Siemens need lot of things.
unless you get good wireman, you need ful wiring harness from MMC system.
THe you need the intake manifold with MAF sensor, distributor, etc.
Finally the cost and work might defeat the performance gained
seanlee
382
3,018
agree with Joeker....
actually i do have a set of MMC injection kit with ECU ...but hte problem is i ask my mech...alot thing need change...the cost end up will be about 2k....and yet..power still the same..coz stock siemens change to stock MMC......why not use the money change the whole engine stil the same price...
But a gain MMC can play alot of thing and install alot of gauge as well...so in the end...is not worth to install it...unless ou change engine....to Dohc like 4g91,93..and otthers...
kennethfong
506
yuhanisa,
very impressive , i bet if u mod further for a 4g15/13 vdo/mmc u can beat GSR and Evos, mind sharing what are the 'recipes'?
YuHaNiSa
195
Sorry bro cant tell the recipe my big bro and friend will kill me they also in zth,they will read...My advice go do basic performance then you will get there...Sample 4-2-1 then must use center bullet..piping not to big just normal and small mufler suit 4g13/15,open port air filter sample hks then air ram must be custom follow the throttel body size..then the air flow sensor put near throttel body but not to near after that disconnect negative - battery after 15sec reconnect back...then start your engine at 10min but dont disturb anything or revving...
you also need to change cable plug,plug bosch super 4..if got money...some of recipe buy alfa romeo coil same as vdo
one more thing dont ever disturb valve tappet too...
YuHaNiSa
195
yuhanisa,
Wahhh that too much...cannot beat GSR & EVO laa...
My big bro & friend know to mod 4G13/15 & 4G93 R3 without change to mmc wiring & ecu...
One of my big bro friend projec is satria 4G92 using doch 4G91 head with vdo wiring & ecu,got no rev cut loh...already beat modified 4G93 SOCH & DOCH ,4G67,4G63 DOCH N/A,4G92/4G93 Mivec also Vtec 1.6...
YuHaNiSa
195
that satria can be locate at perlis,some std body drag car are wellcome to try...our location is alor star...vdo also good...but dont waste money at micro compressor or anything at that shop...
seanlee
382
3,018
this sound like MMC 2nd version for me leh....Got air flow sensor, can customize throttle body and change coil pulak..
coz siemens vdo dun have air flow sensor..only have Intake Air Temperature (IAT) Sensor with Manifold Absolute Pressure (MAP) Sensor ....if customize throttle body....you need to redo and the Throttle Position Sensor (TPS)...which you saw alot electronic and mechanism thing in the throttle body...unlike MMC throttle body...does not have any eletrical thing inside the body such as capacitor, ressitor and so on... you will found in siemens TB..
seanlee
382
3,018
i dont touch the engine...
i think your big bro have done it which he didn`t tell..coz
siemens vdo 4g13 which have less then 70whp......can done 8 second for 0-100m and 16 second for 0-400m.......this equal to a power of 4g93 satria r3 120whp...
which means your current car have to be more then 100whp inorder to do that...
so if you say....do not touch engine, not even single piston change.....
just only add coil increase spark ...how about mixture of fuel....if say....didn`t even adjusting fuel...your car runing super lean...which soon blow up your engine...anyway i think...is all up to your big bro to answer...i guess....coz it create my curiousity too much now...really interesting on your car modding..
RedD
644
3,018
anywhere..
Big sis, hehe:_: ... thnx..tat would help... ermm, but sum questions ere..
bout the piping size.. if im not mistaken.. for 4g13, the piping size would be 1.5" rite? u sed normal.. meaning use bek 1.5"???
n if change spark plug.. wat kind of plug u recommend? thnx :_:
Hi, im changing a metal gasket should i skim the engine head and block with a thin layer ??
---------- Post added at 06:00 PM ---------- 6 hour anti-bump limit - Previous post was at 05:27 PM ----------
Bump, help plsss.
