Siemens VS MMC
ettm_14
605
81
Sifoos arnd need assistance,
What are the major difference/s if I do change my siemens ECu to a MMC ECU on my 4G15??
I have one MMC injector kit in hand-if the difference not going to be alot different then it would not be worthwhile changing?
PLease enlighten me as I am new to ECU and stuffs like these!
Thanks
YuHaNiSa
195
before this i use satria 1.3 siemens vdo..i do basic performance + some recepy from my friend...0-100kmh 8sec and 0-400m 16sec
YuHaNiSa
195
so why wanna change the wiring + ecu mmc ? mmc injector are the same with siemens injector...
siemens vdo kind da like auto learn from what you mod...
siemens vdo have batter fc too my satria 1.3 rm10 can go 100kmh,also my friend car 4g15 siemens...
siemens vdo is free maintenance tuning or setting..
my friend wira 4G15 siemens with basic mod can beat gti pick-up and top speed..so so so
my 1.3 can do 190kmh
my friend 1.5 can do 200kmh
RedD
644
anywhere..
bro, wat a great mod/recipe u gt for ur 1.3 man.. btw, mind share?:_:
mine can onli go 140kph n the pick-up... zzZZzzzz... cant think of wat to do... :confused_smile:
Joeker
Walking Dead
3,580
62
Jinjang
Changing to MMC from Siemens need lot of things.
unless you get good wireman, you need ful wiring harness from MMC system.
THe you need the intake manifold with MAF sensor, distributor, etc.
Finally the cost and work might defeat the performance gained
seanlee
382
agree with Joeker....
actually i do have a set of MMC injection kit with ECU ...but hte problem is i ask my mech...alot thing need change...the cost end up will be about 2k....and yet..power still the same..coz stock siemens change to stock MMC......why not use the money change the whole engine stil the same price...
But a gain MMC can play alot of thing and install alot of gauge as well...so in the end...is not worth to install it...unless ou change engine....to Dohc like 4g91,93..and otthers...
kennethfong
506
yuhanisa,
very impressive , i bet if u mod further for a 4g15/13 vdo/mmc u can beat GSR and Evos, mind sharing what are the 'recipes'?
YuHaNiSa
195
Sorry bro cant tell the recipe my big bro and friend will kill me they also in zth,they will read...My advice go do basic performance then you will get there...Sample 4-2-1 then must use center bullet..piping not to big just normal and small mufler suit 4g13/15,open port air filter sample hks then air ram must be custom follow the throttel body size..then the air flow sensor put near throttel body but not to near after that disconnect negative - battery after 15sec reconnect back...then start your engine at 10min but dont disturb anything or revving...
you also need to change cable plug,plug bosch super 4..if got money...some of recipe buy alfa romeo coil same as vdo
one more thing dont ever disturb valve tappet too...
*Work based on existing GSM/GPRS network and GPS satellites,this product can locate and monitor your car by SMS or GPRS.
Cheap & Reliable , No contract , No monthly Fees , No wiring!!
*Applications-Rental Vehicle,Protect the child/old/the disabled,Protect businessmen,Personnel management.
Functions:...
