Diy Zero Cost Heat Shield
-storm-
96
Hey guys how is my new DIY heat shield for open port filter .
I see K&N open port got heat shield so i jealous i also make my own
i took the concept from this pic
Here is my zero cost heat shield made with oem air box with a small mod,quite straight forward actually but dono is it effective of not what do u guys think?
Now i notice the area is more cooler compared to last time!
Any suggestion to improve it?
unknown1x
369
2
inovative.. well. to improve it..
you knw the space between ur car and ur box.. seal it.. with.. anything u can think of.. hehehe
carb board box aslso can.. hahahaha
then sure 100% better.
dyupol
15
how did you do it exactly? how did you insert the filter to that box?
imoloq
1,068
25
1,648
Use Jacobs biscuit tin for heat shield. I tried it before and it's easy to build. Paint it silver to reflect heat. Or you can wrap it with aluminum foil.
-storm-
96
Just use back half of the oem box la, make an adapter for it from plastic or metal pipe that fits into the oem opening and tighten it with 3m tape on the inside if u want but my pipe fits nicely so no need for that. :_:
nitrus
2,893
35
1,648
If I were you, i would keep it like this..
It's good and cool already, don't totally seal it.. Unless u got a CAI leading to it.. Later suffocate hahahaha
ettm_14
605
81
very creative bro...but if you wanna use back the oem fliter still can?or the mod will have already damage the box?
ettm_14
605
81
but if suffocate also not a bad idea...haha...i mean like my wira auto 1.5 i change to open pod...low torque suffered badly, but mid and high have significant increase...
people say open pod not good for my wira 1.5 auto because it cannot detect or suit it self(the ECU) to the large amount of air intake coming in. Thus might cause damage to it??
I did a heat insulator covering my whole filter without CAI...seen a slight increase in low torque...
Dunno is it placebo effect or not...
just my two cents...
donCityZ
2,293
33
1,648
ARE YOU KIDDING? how to suffocate the intake???
its not vacuum for godsake, no mater how u seal it la..
this is GOOD DIY JOB!
nitrus
2,893
35
1,648
LOL !!!! not suffocate la.. but less air, if wanna seal all up without anything , might as well don't put any CAI right since it's less air to suck?
well, I notice good CAI system, it's either u totally block out everything, and lead a CAI hose into the sealed air filter area (like the pipercross one i think)
OR
you block the surrounding as much as you can yet leave some space (like the K&N heatshield thing, NOTE that it doesn't totally block out everything)
Makes you wonder huh?
imoloq
1,068
25
1,648
Dun argue la. The topic is about heat shield, not how much air the intake can take in. What I reckon is a good setup is that you have an area far away from the engine and feed cold air from your front bumper to that space. It will complement the heat shield. My previous setup involves the relocation of the battery so that there's a cool space away from the engine for the intake.
-storm-
96
Hey guys know anywhere to get those hose for CAI ar? :confused_smile: I cant find it near my place(wangsa maju) and i notice that my fog lights(two round sport light at the bumper) are blocking the path towards the bumper. How ar?
-storm-
96
Don't worry bro, no cutting ,no grinding,all stock, you just need to get an adapter pipe, should be 3inch in diameter or less to fit it in the opening of the box and you are done! :_:
Bro my car is auto lo, so far low and high torque quite balance after i change to 4-2-1 setup! oh ya mine is mmc ecu so should be no problem kua, mayb they are referring to the siemen's ecu wira that the settings cannot be changed? =p
But i know there is a truth behind it, my ecu really can't set the right AFR if it takes in too much air, because i experiment with perdana throttle body and the AFR went haywire and my fc shot up like rocket and making it worse my car no power, too much air already and not enough fuel! perdana throttle body too big opening XD
@zri
1,356
wat happen if d intake havin a hot air ?? i mean for those who put d intake near to d engine bay.. is there any major effect to our engine..??
-storm-
96
Hot air rob you of precious hp i think, the cooler the air the more denser its and more o2 to burn = more power
Thats the theory! :regular_smile:
C
chilskater
Guest
how about kancil carbie?i use K&N, but i think it absorb heat from engine cover. I am thinking of putting a CAI hose direct to it and put soft metal covered with superflon as heat shield...then maybe do scoop for the kancil mata belalang
Hi Everyone....
I would like to start a list of all the workshops with its rating.
I would be happy if everyone would contribute to share information.
For the betterment of all members....
Workshop owners, pls don't comment on yourselves :biggrin:
Thanks mate..... :tee:
