Proton Putra - OEM parts
Jan 31, 2014
2
501
Hi guys. First time posting here even though I had registered since 2014 (I can't even remember that I had registered already lol)
Anyway, earlier this year I bought a 1997 Proton Putra. Originally the car was an auto transmission but the previous owner had converted it into manual transmission. The car was almost in stock condition except for some parts such as
1. Rims
2. Gearbox (using F5M221 code). I believe it is the same gearbox used by Proton Wira 2.0 Diesel
3. Front hood (Ah Beng looking Evo 6 hood or something)
4. Custom Clutch Plate & Flywheel
5. Non-Ori Momo Daytona steering
6. Normal looking gearknob
7. Adjustable suspension
8. Custom front skirt
9. Android head unit with customized head unit dashboard panel
My intention is to re-convert the car into stock condition. So far I have manage to re-convert it:
1. 14 inch rims by AAC (missing 1 wheel cap though)
2. Putra's original 1.8 gearbox (F5M222VRXE)
3. Standard front hood (taken from Wira)
4. EXEDY Daikin Japan 1.8 clutch and flywheels 4G93
5. Original Momo Daytona 4 steering
6. Momo Anatomico gearknob (new ver.)
7. Absorber and spring - KYB and APM
Next project is to change the fuel meter (still having an auto meter), C99 front lip, and head unit dashboard panel (carbon fiber printed design).
Just wondering if anyone know what was the:
1. Stock absorber and spring that Putra came with from factory? Was it KYB absorbers and APM springs?
2. How about clutch plate? Was it EXEDY brand?
3. Which model of Wira or Satria using the same design (carbon fiber) dashboard like Putra?
4. Does Putra originally came with rear skirt as well? Saw some Putra have this rear skirt
minibeany
598
102
543
1. Rims
you can get the gearknob from this seller. MOMO GEARKNOB - ANATOMICO SHORT
none of the dashboard has the fiber design like Putra. The closest might be Wira Aeroback SE.
as seen from the title above, i suffer from low oil pressure....low rev is ok i think, since idle stay at 1 bar plus, crusing stay at 2 -3 bar.....how ever, the oil pressure stay same when i full throttle and rev, when high rev till vtec and boost kick in, pressure dropped to 2 bar only:banghead: new oil pump needed? where can get it? and got aftermarket pump that is more efficient and powerful? will that cause problems if i drive it normally(not rev past 4k rpm and no boosting)? please...
