Some times I think carburetor car is better, for longetivity that is....my old proton saga never gave these kinds of problems, sure the idling wasnt the most consistent, but it will always run.
Everything manual.....lol
My earlier cars were all Carb, even played with Weber......haha
The 1st one rosak already. When my car 1st time engine dead & plug the obd2 port we saw the crank sensor issue. After replacing it everything went fine.
After 2 day then the car went dead agn.
You should find out what happened to the second sensor to cause it to die. Sounds like short or physical damage if you ask me. If it's a short then GG..... if it's physical damage you going off-road a lot ah?
my friend start to persuade me to switch to a mmc.
Lmaoooo
Believe me MMC has it's own set of problems. MMC is also more "dumber" so needs a lot more input from you to make it work. Then there's the dreaded throttle body screw....... hahahaha
Tbh, I dont see how VDO is smarter when all it's sensors left, right and center breaks down so often
My working environment is quite....bad
Construction site as you can think.
Got dust,sand,mud,water pond
Gravel road,cement road, half half off road to be honest. Hahahahahahhaa
Any sifu know is there anywhere selling those wira bottom engine cover? Like thise conti car have at their bottom of car one.
Very2 long time ago when my hair are all still black, there is one company whom makes and sell this.Its a local brand. However i dont recall the name brand or if they are still around. Maybe other member with more white hair than me can shed sone light.
eh....
few second of using the power of internet
Why would you want that? U cant see leaks. Accessibility harder also
After changing my cam & crank sensor the 2nd time this year. I was thinking is it because my working area those stone,sand,mud thing cause this.
If yes,if I install this will it extend the life span of my cam & crank sensor and other part.
Juz my thinking only lah
Was the sensor that dirty?
Is your wira lowered ?
A thread every 60 seconds
