1jz E36 BMW frankensteining
At least bmw1jzcoming is better.....hhahahhaha
Latest update - not enough power is going to the starter. Direct power to the starter and the car fires up, on its own using the battery it won't ignite. Sigh,
wow from buy evo to buy bmw
Technically it's a Toyota. The only BMW part of this car is the shell.
alcyon
800
153
543
Add a starting relay ?
your ignition could be weak.
But wasn't it fine earlier on, before this problem came up?
ixeo
4,788
3,080
KL, Malaysia
Weleh, never ending problems!
shhhh don't jinx it. its not problems, its maintenance for showroom car.
just because its a showroom car doesn't mean you don't have to replace the rubber parts, the wires -- oxidizes, etc.
Owner would like it jinx in that manner......hahhahhahhahaha
cibai.... :thefinger:
Recent updates :
- Car broke down at home. Starter was dead. Voltage detected at the started was less than 7v.
- Oil leaked out from the relocation of the cooler. Braided hoses were leaking.
- Found a few melted relays. Earlier 2 high speed fans were wired to one relay, so yeah melted.
So now the car is with a good mechanic friend. He cleared up all my wires so now my engine bay is super clean. Almost wireless! The birds nest of wires in the passenger foot well as been tidied and ECU relocated to inside the car instead of engine bay (for cooling purposes). So now he's working on the major oil leak. Hopefully after this the car will be ready for the road.
Reactions: vr2turbo
ixeo
4,788
3,080
KL, Malaysia
Please put an air filter on your intake, else your turbo fins will eventually be destroyed. I speak from experience.
Reactions: vr2turbo
i have a pivot megaraizin installed in my car. i noticed that most of the time it shows two readings. 4.7v and 10.5v if i remember correctly. i understand thru some research that 4.7 is the lowest voltage at the start of engine and 10.5 is the real voltage. my questions is how will i know if this is healthy? how will i know if its time to change the battery or my battery has some problems?
i went thru this but still dont get it...
