Transplanting entire aircon system from one car to another
Is it possible to transfer the entire Myvi 1.5 aircon system to a normal 1.3 Myvi?
Or is the Avanza aircon system transferrable to Myvi? I know the compressor hoses are a bit different for the Avanza and needs some modification. But if I were to move the whole thing over - would that work?
loose_end
3,649
197
Malaysia
Why not just key components such as compressor ?
29,998
They aren't completely compatible. The compressor from Avanza isn't a complete fit for Myvi
If that is the case, how can you transfer the whole system. Hose length, bracket and other mounting area, etc....
It's not a complete fit, just need to shave off the mount on the pipe joints and reconnect with bolts and nuts.
Can...why not?
Piping needs a bit of customization works.
Myvi 1.3 & 1.5 using different compressor?
29,998
Make sure the compressor mounting fits well as the belting have to align properly.....:driver:
Can...why not?
I honestly don't know. But I know the 1.5 doesn't have aircon issues. 1.3 aircon gets hot when you drive in the hot afternoon in a jam.
Yeah, that's why I'm asking about retrofitting and whether it's possible or not
29,998
Based on blog attached below:
Myvi 1.5 Compressor can fit Myvi 1.3 but need some modification on belting adjuster bracket.
Myvi 1.5 compressor does look bigger compare to myvi 1.3 compressor
http://senangeja.blogspot.my/2017/06/kompressor-myvi-pecah-magnetic-cluth.html
Myvi 1.3 and myvi 1.5 cooling coil size look the same for me.
Bigger compressor is like a house 1hp vs 1.5hp air con, so should cool faster and better but will zap some power from the engine since only 1.3L....lol
considering how weak it is to begin with - nevermind la. Another -5-10 hp isn't much when you only have 60.
Whenever I go through selected speed bumps (reasonably big / high and/or pointed ones), there will be "brushing" sound coming from the front area. I doubt it is my bumper that's producing the noise because the sound appears when the car is reaching the high point (top area of the speed bump when the suspensions and absorbers are compressed) and also when the car is decending (right after the top area of the speed bump when the suspensions and absorbers stretched). I've spoken to the service...
