DIY - Cooler AirCon for FREE
Supra_Fanatics
Beyond 20,000 RPM!
20,673
3,998
same as mine... :biggrin: :driver:
2 main fan running for radiator...
another one in front of a/c condenser coil.....
if a/c not on...during rising radiator temp, only 2 fan will be running.....
if a/c compressor kick in, all 3 fan will be running.....so now even in hot sunny day stuck in traffic jam also no worries a/c not cool enough :rofl:
INside car also install one fan, then cooler air cond :biggrin:
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
actually i really do got one....
its for my baby..fan pointed to her restraining chair..bcoz of the chair tilted position, the a/c vent not pointing directly to her.....so the purpose of small-usb fan to re-direct chilled air to her :nurse:
ericmaxman
Senior Newbie
664
216
1,543
Hot sunny day okay, but mine got slight overheat when stuck inside SMART tunnel :banghead:
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
hon_cs
251
43
3,028
Ipoh
Very technical info from cvkit leh. I just put the pic here so ppl can understand better. Basically the blue part need to be insulated to get maximum cooling effect rite?
Supra_Fanatics
Beyond 20,000 RPM!
20,673
3,998
bonnet lift! bonnet lift! :listen:
Mine lift on the left side, because of the dent on my bonnet, cannot fully close tight, The front grille making it pop up a bit LOL!
Blue one is the one that is fatter pipe right? In other words cold pipe line?
For my Chery SUV the compressor is in the front near the grill so the hose from firewall to the compressor is long and uses aluminum instaed of rubber hose so got plenty to insulate, but for my VR the compressor is located at the back of the engine near the firewall, therefore the hose from the firewall to the compressor is very short and already using rubber hose, so nothing much can insulate....:driver:
mosesmk
165
32
Selangor
but now my wife complaint too cold at night. Even the temp dial only at 9 o'clock position. Especially when out station where the journey take longer time.
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
haha....me will set at lowest setting so the compressor only work momentarily and then cut
stupidcar
5,000 RPM
Mar 18, 2013
5,567
850
713
How much u got the extra fan and wiring?
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
The Marketplace Top Posts
Hello guys,
I've this problem that my battery is flat due not starting the car for few weeks. Now there's soft alarm sound and i can't unlock my car even manually. Any solution? Is this because the captor system in satria neo?
