4g93 Mivec Turbo Waja project(Many pictures be warned)
Nightstalker1993
267
130
Subang Jaya
Hi guys, kinda new here but definitely not new in the car world. Bought my car in 2011 used and started modifying sound system then slowly went on to mild performance, then all out turbo, standalones and learning to tune on my own. Been one hell of a roller coaster ride definitely. Originally was a 4g18 engine and bolted on turbo with the required supporting mods, but ended up blowing the engine with the rolling launch control(pit lane limiter) feature on my ecu which was setup too aggressively, so decided to go all out while still remaining road legal and decided to do a 4g93t MIVEC build.
Originally posted this on Mivec.co.nz forums, but thought I'd share it here as there may be people out there wanting to use my build as reference. It's gonna be a long post with many pictures, hope you enjoy!
An overall view of my car can be viewed on izso's writeup at http://www.racenotrice.com/diywaja.html though, that article was written when it was still running the old engine. This thread will be more about the rebuild of my new 4g93 Mivec engine as I proceed and will be quite detailed as I am doing it mostly by myself. I have a very close relation to my workshop and mechanic and will be building my engine under his guidance so this thread will be pretty detailed. I had worked for him before so I actually have some experience building engines, plus my old engine was also built by myself as well.
First, photos of my pride and joy! Entered Sepang International Circuit once, a couple of months before my engine spit out it's rod :biggrin:
Speaking of spitting out rod, the damage of my old engine. Goodbye 4g18T, you had served me well :(
New engine arrived from the chop shop!
Came with NGK plug cables, too bad I won't be using them as it'll be converted to K20 COP soon
Turns out it's the RS model I've gotten! Notice the rear water-oil cooler. Jackpot! Internals looked pretty clean, heck even the engine oil drained out of this engine was still yellow. Looks like a really low mileage engine
Can see there's not much difference in terms of lift between the 2 cams
Gearbox code. Couldn't find any information about these online, but apparently they're from the latest model and have a shorter ratio 2nd gear. Too bad I won't be using these as well, sold off the gearbox and bought a long ratio gearbox which is more suitable for turbo and everyday driving.
First time holding Titanium valves. They're mind-bogglingly light!
Tore down the gearbox and... wait.... ARE THOSE CLUTCH PACKS?!
Ultimate jackpot! The gearbox came with Cusco Type-RS 1-way clutch type LSD!
Tore that apart as well, barely any wear on the clutch packs, looks nearly brand new!
Nightstalker1993
267
130
Subang Jaya
Manage to source a 4G93T GSR block and accessories without piston for cheap!
Bought a set of Duratech conrods and 4agze higher comp pistons. Duratech is apparently a Malaysian brand but made in China, though it comes with legit ARP bolts and have a pretty good reputation around. 4agze pistons comes in 2 flavours, the older model have a lower compression and much deeper cavity than these.
Sent the crankshaft for knife-edging and my mechanic helped me chamfer the oil holes
Sent everything for balancing
The pistons came with original Toyota rings. Ring gap looks good!
Bought a set of Taiho engine bearings, plastigauge check failed! These bearings have pretty shitty clearance. Manual states that factory clearences is up to 0.05 and limit 0.1, too close to the limit for comfort
Took the old bearings from the 4g92 and measured, got pretty tight clearances! Pretty surprising considering these are old bearings.
Taiho bearings vs GSR stock bearings(2 hole) vs MIVEC stock bearings(3 hole)
Not contemplated with using old bearings, the hunt for original MIVEC bearings starts, and in the end manage to source only RED main bearings, costs a whopping RM500(USD120~) for just the main bearings! :shock: Clearance same as the old Green MIVEC bearings, so I guess it's usable.
ACL Race bearings for the conrod as I couldn't source the MIVEC conrod bearings and the conrod bearings seem to have no difference in design unlike the main bearings.
Reactions: ^pomen_GTR^
Nightstalker1993
267
130
Subang Jaya
My new flywheel, clutch and gearbox. 9" flywheel from an Evo 3 4g63t modified to fit the 4g93 by modifying the starter ring and machining a groove in the center where it meets the crankshaft
New gearbox code, from a SOHC 4G93 with super long ratios, good for cruising
Finally the bearings and pistons gets installed!
And just as quickly as it was we installed, we hit a snag! The new forged conrods are JUST BARELY touching the block, but it's definitely touching!
No choice, had to take everything apart again and clearance the block
Put everything back together again and install the rest of the short block. Also preloaded the oil pump pressure relief valve spring with a nut to increase the oil pressure but did not take a photo of it.
Cleaned up, de-rusted and resprayed the metal bits of the oil sump
With the block done, next up is the head.
Ported the ports slightly and gave it a smooth finish.
Using a special grinding paste and a hell lot of time, hand-lapped the valves until it's mirror finish for ultimate sealing
Shiny shiny valve seats
Denso IK24 Iridium spark plugs. Perfect for turbo
Time to CC the head, in order to calculate compression ratio and also to equalise all 4 squish area volume. The theory behind this is to ensure that the compression ratio of all 4 cylinders are the same and in theory should reduce vibrations or unequal fuelling issues and possible performance gains.
Done with a Burette, small piece of perspex, grease to seal the perspex and the measuring liquid itself is Diesel
Roughly 47cc per chamber
Slight differences between each cylinder, but in the end managed to equalise all 4 volumes down to 0.1cc accuracy by drawing out the gasket as a guideline and grinding material off the head.
After grinding and polishing the head chamber
Close up of the chamber after grinding and polishing
Compared to before
Nightstalker1993
267
130
Subang Jaya
Depo OLED Wideband w/ Bosch LSU 4.9 KIT
Oil pres, Oil temp and water temp sensor to be wired up straight into the ECU
ARP head studs. Apparently the same as a 3S-GTE
My TD05HR-16G off an Evo 6
Twin scroll, should improve low end spoolup and reduce my boost threshold
Looks like the previous owner ran an EGT sensor, the turbine housing came pre-drilled. Perfect!
Original Evo 6 blow off/recirc valve. Can't afford a 'real' blow off valve yet, this will do.
MAC boost solenoid valves on standby for closed loop boost control and boost by gear
And at the heart of it all, my MS3x from my previous build will be brought forward and reused again
Nightstalker1993
267
130
Subang Jaya
Measured the volume above the piston at TDC, these pistons gives me a reading of 6.9cc
After that, I measure the volume of the cylinder at TDC as well. Preperations need to be made to prevent the liquid from leaking and this is achievable by packing the gap between the piston and cylinder with as much grease as you can stuff, then wiping it down after :lol: . You can see the grease in the gap.
Measuring the cylinder....
Writing down all the variables and calculated the compression ratio based on the 1.5mm thick gasket
1.5mm gasket. Interesting thing is the brand of the kit is SOWA but the gasket itself have Mitsubishi markings :roll:
Copper-sprayed the gasket then installed the ARP head studs
ARP head studs instructions. 60 ftlbs of torque
After torquing everything down
After the head had been torqued down, managed to measure the compressed gasket thickness is actually 1.2mm, so based on that, re-calculated the compression ratio again. The final compression ratio calculation is as below
My target compression ratio is actually 9:1 but oh well, not too far off and I guess it gives me slightly more room for boost :burnout:
Nightstalker1993
267
130
Subang Jaya
Took out the breather port, drilled it larger so that I can fit a larger diameter hose to accommodate the extra blowby from a boosted engine.
And inside the cam cover there is actually a rubber hose. After drilling the cam cover, i filled the gap between the cam cover and the hose with some epoxy to ensure the oil/air separator is still working as designed.
Larger breather port
Cleaned up the cam tray with petrol before installing it
Bought these Works Engineering adjustable cam gears. Says Designed In USA but I highly doubt so. :biggrin:
Camshaft and cam tray installed
Test fitted the 159t timing belt. With the stock pulley bearing the belt was running a tad too loose. Replaced the idler pulley with a larger one from a 6a12 and it fit perfectly!
6a12 idler pulley
Evo 3 flywheel, machined to fit the 4g93 crankshaft
And in this photo I just realised I forgotten to install the back plate. Can't seem to find that plate....
Nightstalker1993
267
130
Subang Jaya
Here's my ebay special GREX-style copy oil cooler adapter with built in thermostat
Need to be really careful with these ebay special stuff as mine came with the thermostat installed wrongly, after correcting it, it looks like this. Luckily I did not install immediately else it would probably mean extremely limited oil flow into the engine.
Banggood special EGT thermocouple also arrived and fits nicely in the turbo hole. Need to monitor EGT's to prevent engine meltdown
K20 coils sourced and fits nicely after some minor cutting
Got a mint condition Evo 4 intercooler :cool:
Have to modify the clutch pump mounting point to prevent blocking the turbo inlet
Engine ready to go in!
And it fits in nicely
Wired up the coils
My custom turbo manifold arrives
Nightstalker1993
267
130
Subang Jaya
After some measuring and cutting and welding and repeating of the manifold, finally got the turbo to sit just right, ever so close but never touching the radiator
Look how close that actuator lever is to the radiator!
Radiator is a (i assume) China 'SARD' thick radiator, and also got a used Maradyne fan off my friend, also made a heatshield for the turbo hot section to prevent it heating up my a/c compressor, radiator and other components
Heatshield for the turbo
Speaking of actuators, my original actuator was leaking so had to source for a replacement, got another ebay-special Kinugawa adjustable wastegate actuator and is pretty decent quality
After installing the actuator
Beefy large diameter steel braided hose for the turbo oil return, and intercooler piping in the makes
How it looks like at this point now (circa November 2016)
Nightstalker1993
267
130
Subang Jaya
My midbox, or some call it resonator? 3" straight flow large size for quiet
JDM Tanabe Hyper Medallion 3" straight flow muffler, taken off from some Subaru if not mistaken, also chosen for quietness.
Intercooler pipe taking shape, and oil cooler sandwich plate installed.
Intercooler and exhaust piping next to each other, later on I wrapped the exhaust pipe with exhaust wrap.
Oil cooler adapter plate
3" stainless steel exhaust, wrapped the length that passes under the oil sump to prevent heating the oil sump.
Oil cooler lines installed.
The Hyper Medallion looking good
Rats invaded my wiring halfway and had to redo my coil wiring.
Air filter and intercooler pipes gonna take up the space where the battery originally was, so gotta shift the battery to the back. Chosen this MSB VRLA AGM Lead Acid 65AH deep discharge battery designed for backup power industrial use as my main battery. It is truly sealed compared to your regular 'sealed' battery which may still emit hydrogen gas and should also last longer than the average car battery.
For the main cable, chose this 70mm^2 welding cable, equivalent roughly to 2/0 gauge. All of my friends were telling me I was crazy for using this diameter cable for this purpose :lol:
Measured the length properly and got it professionally crimped
Put in some braided sleeves and triple layer'd braided sleeves for areas where I consider might be higher risk
Battery mounted in the boot, with the positive going straight to the front while the negative goes to a 150A circuit breaker.
Nightstalker1993
267
130
Subang Jaya
Swapped the oil cooler to one from a Pajero(I think) as I found out later my Evo oil cooler was leaking, also installed an oil cooler fan, which till today, I had still yet to wire up :lol:
And since this project took so damn long, the internals started to rust without me realising, eventhough I had poured oil on the cams and cranked the engine over a couple of times to let the oil flow before I installed everything, so the cams and rockers had to come out for another overhaul session.
After cleaning out the rust, some parts of the cams had pretty severe pittings. Quite sad as these are RS cams, but I can't do anything about it :(
All clean and re-lubed
Reinstalled the upper head and spray painted the cam cover, intercooler piping still on the way, air box for air filter also in the makes.
Got me an old stock Turbosmart FPR 800 v1, which ultimately would be replaced by the latest FPR 800 as this v1 had a problem of dropping fuel pressure as my RPM climbs for some odd reason.
Some wiring works on my MS3x wiring adding the MIVEC output, coil output and some other outputs. Out of sight, out of mind yeah? 8)
Got almost everything done, engine bay shot now. Aircond and power steering pipes and hoses had to be custom done to fit. And the car runs!
Feels so good to be finally able to drive the car
Got a pretty mint Synapse Synchronic BOV to replace the stock Evo plastic BOV
BOV output recirculates to the inlet
Replaced the V1 FPR 800 with the latest FPR 800, fuel pressure remains steady at all RPMs
Latest engine bay shot
Replaced my 7-year old Walbro fuel pump with a DW200 for reliability sake as the Walbro's are known to seize at times when it's older, leaving me stranded. Already happened once.
Also purchased a brand new oil pump from Amayama as these Mitsubishi oil pumps have quite a bad reputation of killing itself plus I am not sure of the past history of my current oil pump nor did I open it to inspect before installation. Will install this during my next oil change.
Some basic on the road tuning and the engine feels pretty good, revs up to 8400rpm nicely and was boosting at 0.5bar, just today I increased it to 0.8bar and it feels awesome!
Nightstalker1993
267
130
Subang Jaya
Some photos of the car currently. Nothing special, but I'd say it's quite the sleeper, minus the Evo intercooler poking through the bumper :lol:
Now on my to-do list would be upgraded brakes and repaint the car. Probably upgrade to larger rims in the future, but engine wise everything seems good. Long ratio gearbox cruises at 110kmh @ 2700rpm and 2nd gear tops out at 130kmh @ 8400rpm. Somewhere in the future would rent a dyno and give it a final tune and probably increase boost to 1.2bar. Current estimate is around 200-250hp at 0.8bar probably. It is currently my daily driver, so far clocked around 5000-6000km already and am running Amsoil Signature 5w50 oil after the initial 1000km run in with Amsoil run-in oil.
And this concludes my engine build. Hopefully this will be the last time the engine needs to be worked on :lol:
Thank you for your patience and support so far, and also thank you to this forum for still existing when most forums are closing down and shifting to Facebook instead. I really hope this forum will not end up like that.
Cheers!
Also, here's a short video of a 2nd gear pull when it was still boosting 0.5bar. Currently turned it up to 0.8bar and still testing and tuning the closed loop boost control. Should be turning it up to 1bar and ultimately 1.2bar in the future and a proper dyno tune.
https://www.youtube.com/watch?v=Yho__XmHKpk
Nightstalker1993
267
130
Subang Jaya
Some say this is the fastest Waja in Subang and Glenmarie area.....
mana ada o, i drive slow slow only :sleep:
Waja lanci ni
burnout cover picture more lanci
fastest subang in hong
fastest jack on the road
this is refreshing! what a ride :adore:
Thanks! Still far from complete though, even the brakes are still stocks :rolleyes:
My car entered workshop around end of October 2015, and engine started only around July 2017, during that period I rode motorbike only :beer:
Nightstalker1993
267
130
Subang Jaya
very very impressed!!
so much win here
Some things I kinda regret not doing though. Did not check the valve-to-piston clearance as I didn't know how to activate the high cams on the bench that time but now I know.
my future reference...:adore:
What are you building? :biggrin:
Now really considering an Accusump though. Last week took a hard right corner and my oil pressure sensor showed that the oil pressure was fluctuating wildly, and the oil level was around half that time, then I proceeded topping it up with a full liter of oil and it is now overfilled by 1/2 dipstick and the pressure seems stable during the corners.
Can see the green line below starts to fluctuate during the corner whereas my RPM is mostly constant. :bawling:
Datalogging is scary...
Nightstalker1993
267
130
Subang Jaya
Ohh and also forgot to mention, just got my engine endorsed in Puspakom and JPJ as well around 2 weeks back, did it myself without runner at Glenmarie. Passed the brake test without issues with the stock brakes and Evo brake servo, and handbrakes tightened kaokao before I went in. Had a friend told me they won't check lights and stuff so didn't bother removing my HID, but end up kena sangkut the HID and front window tint. Went to workshop and replaced the bulbs, removed the tint and went back puspakom before lunch and got everything done. If those 2 never sangkut probably would've completed everything within an hour. Updated JPJ information in Padang Jawa, took me like 15 minutes including change name samore as my car was under my mom's name before this.
So important things to know when sending the car to puspakom yourself, they check lights, signal lights, horn, high beam, brake lights, rear lights as well so make sure all those are working and legal :laugh:
Reactions: minibeany
Guys,
need your opinion on RCS vs titan. I know that both of the product are custom made absorber.need your comment on quality and ride experience. I have use titan before and yet to know how is RCS compare to it. Planning to put into my ride in near future.
rgds
