4G93 DOHC with intake and exhaust reversed?
RENESIS VIII
7,063
950
Ipoh
the pink engine is CK version.. then they mate it the whole engine with CA gearbox (normal wira/satria layout)....and use back the CA version normal valve cover.....just to play eye trick on you guys.... :biggrin:
So, it is a CA gearbox and block but CK head with CA valve cover? I'm surprised the CA valve cover can fit in nicely.
ca gearbox, ck block, ck head, ca valve cover nicely done mix n match
RENESIS VIII
7,063
950
Ipoh
CK block? But CK block's flywheel area is on the opposite side of CA block. Unless this person really reversely mounted the CK engine to achieve this setup?
as i said....just rotate the block 180 degree from its ori position and use back CA gearbox....
Hi guys, as topic states my coilovers need a rebuild. So far only place that rebuilds hypermax 2 that I've been able to find is Garage R in Singapore.
Suggestions?
