4G93 DOHC with intake and exhaust reversed?
RENESIS VIII
7,000 RPM
7,063
950
Ipoh
the pink engine is CK version.. then they mate it the whole engine with CA gearbox (normal wira/satria layout)....and use back the CA version normal valve cover.....just to play eye trick on you guys.... :biggrin:
So, it is a CA gearbox and block but CK head with CA valve cover? I'm surprised the CA valve cover can fit in nicely.
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
ca gearbox, ck block, ck head, ca valve cover nicely done mix n match
RENESIS VIII
7,000 RPM
7,063
950
Ipoh
CK block? But CK block's flywheel area is on the opposite side of CA block. Unless this person really reversely mounted the CK engine to achieve this setup?
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
as i said....just rotate the block 180 degree from its ori position and use back CA gearbox....
Following two global recalls on certain Toyota and Lexus models, UMW Toyota Motor Sdn Bhd (UMWT), the authorised importer and distributor of Toyota and Lexus models in Malaysia will carry out Sepcial Service Campaign (SSC).
The First recall: To fix the possible crack in welded areas for curtain shield airbag inflators. If the inflator separates, it could cause an injury to the present...
