4G93 DOHC Problems
drummydrew
471
hello there all sifus, i've only got time to surf back in here for and seems like alot has been going on! i enjoyed reading pages of feedback in the Satria 1.6 thread :biggrin: anyways im back with some update on the "gurgling" noise which was mentioned last time, which is NO update :itsme:
sent my car to another supposed more trusted mechanic and he told me it has nothing to do with the fuel system so it could very much be a loose nut, he said. putting that aside, here's another recent starting problem which requires me to pack an extra battery in the trunk for emergency jump start - i have a fairly new battery considered its installed earlier this year to begin with, left the car untouched for 2 days, realized battery's dead/alternator lost charge so i jump started it, WORKED, let it run for 15 minutes with AC and lights all on, then realized that there's a power loss problem:
https://www.youtube.com/watch?v=3FNzb1U8b7s&feature=youtu.be
turned it off, then this happened when i tried starting it again:
https://www.youtube.com/watch?v=qSlY8EQqjfw&feature=youtu.be
any word? :smokin:
any word? :smokin:
Bro, your alternator ok condition? Stock grounding worn out? There's one grounding from battery negative to chassis and another from chassis to engine block (default). Perhaps those are worn out.
any word? :smokin:
Yup, first check you alternator charging rate. If alternator problem, then no charge going into the battery.
If alternator ok, then check battery, because maybe battery is dead cannot store incoming charge.
Oh! if all okay and battery goes dead after a few days, check for parasitic current draw also
RENESIS VIII
7,063
950
Ipoh
If your battery is not charging, then the battery light indicator should be on at your metre/instrument panel console. At least that is how i noticed that my alternator is dead few weeks ago. The light just doesn't go off even after i changed into a new battery.
Problem is sometimes it does not light up. Of course normally it does if alternator fails.....
drummydrew
471
hello sifus all, i wanna ask if anyone has any idea what is the normal charging rate for 4G93's alternator?
recently fitted a new battery, FPR and stepper motor - the gurgling noise as mentioned before is gone, highly suspected that the old one was faulty causing inconsistent flow hence the noise. However now, a new noise has arose :banghead:
as shown in video, with both AC on/off.
https://youtu.be/FP1pMF32_zw
Sound like the old style dial up modem sound.......hhahahhaha
Jokes aside, sound like scrapping on something, check the bearing also.
Battery charging rate normally 13.6 to 14.4v
sanekit
Dec 9, 2015
1,616
157
Have u checked the pulleys bearings?
Jaring dial-up. Hehehe
drummydrew
471
:rofl: that's what i thought when the sound came up! 56K modem from the past dialing up in my car lol!
which bearing exactly should i look into? AC compressor/cam/crank pulley? :confused:
sanekit
Dec 9, 2015
1,616
157
All. Does it gets louder when you drive or just when idling? Mine had that before. Just weird noise when idle due to the tensioner pulley bearing worn out.
my car stranded yesterday infront KFC...car cant start...when turn the key no whining sound from the pump...try to shaken abit the the f-pump relay..but not working like b4 as what i always did..., left the car whole night there..nxt morning came with my mechanic.. they give a try and suddenly the car can start...can hear the f-pump whining when put car key to 'on'.. the question is...what happen to my car?? izzit the fuel pump relay going bad or that the sign of my fuel pump will gone after...
