Pros and cons of engine braking?
RENESIS VIII
7,063
950
Ipoh
Is there any specific harm to the car if engine braking is occasionally applied? Like will the transmission, clutch or anything else be prone to damage?
I drive a manual transmission car and I tend to use engine braking a lot to slow down my car instead of using the brakes. Some people come and tell me that what I am doing will eventually harm my transmission.
So, what are the thoughts and opinions from you all regarding engine braking?
Tom
TIMETOATTACK
Jul 6, 2000
5,562
3,229
It really depends how you use it to be honest but manual transmissions hardly break in road cars.
As long the transitions between gears are smooth, clutch is applied properly I don't see why there is a need to worry. There is engine braking even in today's modern dual clutch transmission.
You should of course always use the brakes as the priority. For example, to stop before a toll plaza coming in at over 100km/h on engine braking is simply not wise.
Having said that, to conserve clutch and transmission wear some quarters in racing adamantly discourages any engine braking at all, especially in endurance and rely 100% on the brakes alone.
I use engine brake all the time, but if slow speed then use brakes only, if very fast, will be brakes first to slow down then engine brake to slow further before harder braking. In a way drop gear to engine brakes especially coming to corners then no need shift to accelerate out.....lol
RENESIS VIII
7,063
950
Ipoh
I do use it occasionally. I tend to look far ahead to see whether do I need to stop or slow down my car. If I need, I will normally start to downshift from as far as 50 metres away from the targeted point and I'll use the brakes when I'm quite near the target point.
Like what Tom said - no issues but don't go and downshift 5 to 1 or 2 la.
I din't let the revs to go over the red line but once in a while, I might let it go until around 5000rpm which I am not so sure is that fine or not.
I downshift at corners too when I am going fast. Normally at higher speeds, I'll try to corner at a higher rpm lets say like around 3500 rpm and above because I feel that it is easier to slow down in case I need it. At high rpm, the speed will drop faster after I release the throttle compared to lower rpm. At least this allows me to slow down the car in a faster way before I start to apply braking.
Hmm you mean you downshift first before you brake? You should do it the other way around which is brake first then downshift. If you downshift first, that puts more stress on the gearbox and engine, and you risk locking up the tires especially when driving fast and you're already at high engine rpms. If you brake first then the transition between accelerating and slowing down would be smoother (less chance of lock ups), then it also allows the rpm to decrease to acceptable & optimal level first before you downshift hence minimizing the transmission stress. That's why there's the heel & toe technique where you brake first with the top of your foot (supposedly the toe area) then blip the gas with your side foot (supposedly the heel) to rev match for downshifting.
Tom
TIMETOATTACK
Jul 6, 2000
5,562
3,229
It is okay to downshift a gear or maybe 2 before braking, just to shave some speed. Fully depends on situation of course.
for example:
- Approaching the toll plaza say 500m away from 6th to 5th or 5th to 4th before applying the brakes
- Approaching a slower car on the fast lane
- To anticipate an overtaking maneuver
Tom
TIMETOATTACK
Jul 6, 2000
5,562
3,229
How does this apply to non-DSG auto transmission with tiptronic?? Is it ok to engine brake?
All transmissions are designed to take these basic situations.
Like descending a hill on a lower gear or ferrying a car load of people and cargo.
As long as the tiptronic system allows you to downshift, it should be safe enough for the said engine speed.
KenDiriwan
1,283
225
kendiriwan.multiply.com
I use this method daily, basically bumps, traffic light, round about as long as there are need to slow down. Not sure about the rest but i am those take especially bumps with care preferred not to roll it over naturally even on low speed.
for example:
Yes, of course in normal cruising speed ad relatively low rpm still ok to downshift first but reading his story above it seems like he's also on a fast, high rpm mode while doing that.
Anyway for me personally, even when normal/cruising drive, most of the time I still brake first. The only rare occasions where I may downshift first are:
- the 3rd case in your list above while I'm already in too high gear (say already in 6th but only at 100kph, then I drop it to 4th or 3rd to overtake fast or to distance a tailgater behind), or
- I was driving like a hooligan to lock the rear to slide when still teenager back then!
marv3
496
57
I also usually brake first then downshift and i will balance the amount of pressure on brake pedal with the engine braking :driver::driver:
RENESIS VIII
7,063
950
Ipoh
Yes, I downshift before I brake but not at high engine rpms. If I am at 3500 to 4000rpm and above, I don't downshift.
for example:
You are exactly right on the examples that you gave. Those are the kind of situations where I normally downshift to slow down the car.
Well for me even in those circumstances most of the time I still brake first at least a little. Anyway it's up to you if you prefer to downshift first. If you're just concerned whether that will break your car, then at low rpms should still be ok but if you're driving fast in higher rpms then you should brake first.
just one...during high performance driving...engine braking with over-rev will destroy the engine...
other than that there is no problem at all
RENESIS VIII
7,063
950
Ipoh
Will the clutch worn out faster from engine braking? My car engine is still stock.
Tom
TIMETOATTACK
Jul 6, 2000
5,562
3,229
Well if your revs are matched and clutch is applied properly then the wear on the clutch plate should equate regular wear and tear
Nothing wears the clutch more than situations like half clutch or releasing the clutch pedal too slowly during higher revs.
Sent from my SM-N9208 using Tapatalk
RENESIS VIII
7,063
950
Ipoh
I don't rev match when downshifting. Seems that I am doing it wrong.
Tom
TIMETOATTACK
Jul 6, 2000
5,562
3,229
Yes, you should start adapting and applying it at your next drive Renesis
Each and every downshift requires a blip of the throttle
It is the only method to rev match
Failing which, these scenarios will definitely occur:
  • Sudden jerk
  • Accelerated wear
Of course one can get away by being patient and releasing the clutch pedal gently to cure jerk but let's face it, it is inefficient
Let me try to help,
Rev matching during downshift is simple and easy to do,
  1. Since you are already pressing the clutch and downshifting at the same time
  2. All you only need to do now is add one more step, blip the throttle
  3. As you press the clutch, simply give a quick jab to throttle
  4. Find your sweet spot,
    • add / reduce or throttle blip (the lower the gear the more the blip, vice versa)
    • timing is important, doing all at the same time AND at the same speed is key here
  5. Practice
  6. Tell us your findings
Good Luck
RENESIS VIII
7,063
950
Ipoh
  • Sudden jerk
  • Accelerated wear
Let me try to help,
  5. Practice
Good Luck
Thanks for the guide and help, Tom. I appreciate that.
I have actually tried something like this before when I am downshifting. Sometimes when the rev matches, the downshift transition is smooth. But there are also many times when the rpm is not high enough to rev match after I blip the throttle. So there is still some slight jerking as the RPM climbs slightly higher after I release the clutch.
I will try it again on tomorrow as I will be going for a long drive.
hI there,
Can anyone tell me is satria 1.5 pillow ball mounting (front and rear)
same as satria 1.6?
what will happen if i use a faulty pillow ball mounting?
please advise
