Emanage - stock evo 7
satria81
813
18
5,018
PETALING JAYA
Hi all,
My car is at 100% stock condition but I recently noticed that an EMANAGE was installed by previous owner.
What difference would it make if I were to remove the EMANAGE. Would it reduce the performance or. . ?
Kindly share your thoughts.
Note: I have no plan to mod my car, I bought it simply because it was at stock condition or just the way I like it to be
thanks all !
Regards,
Satria81
ixeo
4,788
3,080
KL, Malaysia
Depends, did they increase boost or not..If they increase boost, then yes it will reduce performance, and the boost without fueling may kaboom your engine.
satria81
813
18
5,018
PETALING JAYA
hi ixeo,
thanks for the reply.
I do not know if the boost pressure has been increased . how do I check..
would it be better to run the car stock without the emanage, please advise
peeche
395
165
Sin City, MY
hi ixeo,
What is your current max boost readings? Did you have any boost gauge installed?
mag9556
2,770
43
1,648
better dont remove it as even stock also it made different...
so good, buy car free e manage...
satria81
813
18
5,018
PETALING JAYA
yeap
but the emanage device looks old and faded :) I am not really liking it but if it makes a positive difference I shall remain with it
slipar
500
61
banting - pj
look for a tuner..have the e-manage check..got tweak or not..
or maybe the tuner can fine tune it a bit more..:biggrin:
satria81
813
18
5,018
PETALING JAYA
I am wondering if the emanage is the culprit as I am only getting 270kms +/- for a tank of fuel presently, given a choice, I would go for stock set-up
scoupe
1,087
37
5,148
shah alam
with an emanage u may get better fuel economy depending on tune. stock ecu runs the car with very safe parameters.Normally on a stock engine u cnt do much with an emanage but trim down these parameters. you might wanna invest in monitoring systems for your car. if ur running boost its always best to get good quality gauges to monitor. or else you wont knw ur oil temps, u wont realise overboost and etc..
ixeo
4,788
3,080
KL, Malaysia
Evo 7.. ECU can be flashed right? Why want to install E-Manage, really tak faham.
If there's no boost controller in your car, and the stock boost solenoid is controlled by the stock ECU, you can safely remove the e-manage.
peeche
395
165
Sin City, MY
try to re-tune your e-manage. you'll get much better fuel consumption with a good tuning. Possibly the previous owner mod this car before and change back to stock before selling the car, but he didn't send it for re-tune. :listen:
satria81
813
18
5,018
PETALING JAYA
I would agree that the previous owner would have modded cos why would someone run the car with an emanage without race cams/ pulleys etc
my fuel consumption is high. from full tank of petrol up to empty, I wud hardly get 270kms.
peeche
395
165
Sin City, MY
Ouchhh, that's hurt. Such a fuel guzzler. It might be right, but some of Airtrek's owner install e-manage to get better consumption and run safely on ron 95.
7,514
evo7 run emanage? cheap fast way for mods...but the tuning is rough... ecu can be flashed but use piggyback for what....
i suspect prrvious owner either too much money or scanmed by certain ppl/shop....
and my suggestion...go for a dynotune to check the engine tuning first.......after get the baseline then remove the emanage...sell it and send your car for ecu flashing and tune to suits your car "proper" needs....
and please get essential meter for easier engine monitoring...most: boost+water temp+oil temp gauge...
A Post Every 5 Mins
Guys ... a friend of mine got his SGTi stolen last month in SS15 (Subang Jaya).
He just told me though ... May be if I post it here somebody could might have seen it.
Its Satria GTi with reg. no WHQ 8676
It's all standard bodykit but there's no lip as it is broken and a big dent on the passenger side.
The headlamps light is one orange and one white (dun ask me why)
Interior is all standard but with digital e-cond.
Just helping a friend here ... Thanks.
Any help/ clues is truely...
