- Sep 17, 2008
- 20,673
- 3,998
- 1,713
Wearing already that time haha! Just want to check on my eye power.Maybe because you first timer not wearing specs, check first whether you need or not?.....
For free? In the end was it a balancing issue?Went back to Hup Shun after a week plus, requested to do a rebalancing.
Because i hit a deep pothole at traffic light <5kmh. Why the weight so easily came off?
They happily did it. Even reshine and recheck pressure lol.
like a bawseFor free? In the end was it a balancing issue?
Just a note to everyone : The TS shared his own experience with this shop and that's that. No need to make him feel like a pariah just because you guys had a better experience than him with the shop. You had a good experience, good for you. Maybe they are treating you better because of the TS's complaint here. You'll never know.
Which kind of eye test 1st? If u say using just the machine outside the shop where you place your head on. That's free.Since when theres such a thing? I went it my whole life, all foc.
Sure the weight came off?Update-
Well, he just changed tyres there, so should be free to redo if the tyres still vibrate. Of course don't tell them you hit pothole etc. etc., just complaint still vibrate....For free? In the end was it a balancing issue?
I am just sharing my own experiences too?For free? In the end was it a balancing issue?
Ohhhh, okay. Those I only do when I make specs.Which kind of eye test 1st? If u say using just the machine outside the shop where you place your head on. That's free.
If it is more detail eye checking where they take you into a room, that's the one that I was charged. I went to Cosway optical also they want to charge, I went to Sungai Wang, all also charging. Unless you were once a customer there. But the one that I usually go, already closed down.
:O Nikon lens and Carl Zeiss heheCuz gf sister is working in specs shop in singapore. Can get cheaper ma
Anyway back to topic haha!
Hello... "Note to everyone", not "note to stupidcar"I am just sharing my own experiences too?
Yep. Now vibration from the back. Sigh.Hello... "Note to everyone", not "note to stupidcar"
Anyway, did the rebalancing fix the problem and was it done free?
I don't think you know where the vibration is coming from. The rear tyres were not touched, right?Yep. Now vibration from the back. Sigh.
And yes, its free.
Okay, when i hit the pothhole, I hit it with my 2 left tyres, front and back.I don't think you know where the vibration is coming from. The rear tyres were not touched, right?
Let me ask you, how the vibration being felt, or can explain what/how is the vibration?
Means your whole car shaking? Then yes, rear tyre off balance but can feel only at quite high speed. Maybe rims dented also....Okay, when i hit the pothhole, I hit it with my 2 left tyres, front and back.
My steering judder very badly going beyond 100km/h.
After ytd rebalanced, my steering doesnt judder anymore even at 130km/h.
Today I felt my ass is shaking, suspect behind balance ciao also.
But its at the back so i'm not worried/annoyed.
5kmh kena pothhole, wont dent gua.Means your whole car shaking? Then yes, rear tyre off balance but can feel only at quite high speed. Maybe rims dented also....
BIG or Deep pothole leh!......5kmh kena pothhole, wont dent gua.
Doesn't feel that deep or big weh.BIG or Deep pothole leh!......
All using double sided tape leh! If not, how to stick, apply rubber glue ah! then need time to dry....hahahahaDoesn't feel that deep or big weh.
Feels like normal pothhole, I even faced worse ones.
But they held up. Normally what do they use to stick the weights?
I realized Hup Shun is like using foam double sided tapes.
Yeap, noticed that.All using double sided tape leh! If not, how to stick, apply rubber glue ah! then need time to dry....hahahaha
The stick on weights are used in alloy rims. Especially those the rims edge do not allow the hammer on weights. Anyway, hammer on weights will scratch the rims. hard to wash the rims and will look ugly. Normally they stick just behind the rim spokes. For the inside normally they use hammer on weights. If they use stick on ones then they will be located at the rim edge top side.
You love holes?.....................oh! miss the pot in between.....hahhahahahhaahhahaYeap, noticed that.
Just now, kena poth holes on my left 2 tyres again, at SS2.
