4afe "makan" engine oil really quickly
Hi fellow ZTHians,
Need some help here.
I drive the ae101 (21year old car) with stock 4afe engine. It was the family car before being passed over to me. In my hand, I bring the car for service/engine oil change every 5000km/every 3 months.
So the problem is: the engine oil level will drop till almost empty before 5000km service interval (less than 3 months). Have tried using different oil rating but still the same problem and recently realised the problem is worsening. Last time still can go about 4000km before the oil level starts dropping, now about 3000km already less than half left.
Have asked the mechanic i usually go to, and he suggests to send it for a full overhaul and quoted me a price of about RM4k+, saying it will include changing all the seals, ring and rebore (or something like that). 4k is a very heavy sum for me cos i'm still a student.
Should I go ahead with the full overhaul?
What is the normal price range for this kind of overhaul?
Any second opinions on how to fix the problem?
Please and thank you very much! :adore:
Quite normal for a 21 years old car. If engine still running proper just use thicker viscosity oil like 20w-50. Don't use FS with 5w as this oil is too thin. Buy another can of engine oil for top up. My engine also consume oil already and I just top up every now and then when required...:driver:
how bout those additives that claims can stop oil leaks, is it ok to use it:confused:
Fouling as in mucking up the spark plugs. Overly burnt or wet plugs = problem with the spark plug = fouling.
One of the best ways to save money is to learn to do it yourself. If you have the budget spend some money on a good ratchet set with all the size sockets. Then go ACE and buy the spark plug socket (find out what size your plugs are first. Google!) and get a long ratchet extension. Removing the spark plugs is dirt easy and a great way to get started with DIY.
Yessss. Poison TS with the power of DIY.
A set of socket wrench is the best investment!
not really for much bad piston rings / valve seal /plug seal leak case. those additives are honestly just adding viscosity to existing engine oil (and just that) - which may work sealing needlepoint gasket leaks or very very thin cylinder gaps. it's just like using 20/50 oil but the oil will still burn, at lower volume than of 10/40 or 15/40 oil. Dont know about how much viscosity added to 20/50s with those additives but I guess it'd be painful enough for engine bearings.
That is why just use 20w-50 oil. Anyway, these oil were made for older generation engine like his......:biggrin:
Actually is there anything that can be done so that old engines dont need to use thicker EO?
Is it Overhaul the engine and change the engine parts to new?
Depends on the condition of the engine. If it was abused since day 1 then you'll probably need to a complete overhaul.
Guess that's the reason why cvkit drive uncle speed. :driver:
I need to learn to do that I guess...cannot always tekan :rofl:
Basically can open the header and check the piston and cylinder wall. If cylinder wall still good but piston loose can do ring change. If cylinder wall not good and piston very loose then complete change, means piston and rings and cylinder wall re bore aka Total overhaul.....:smokin:
---------- Post added at 11:09 PM ---------- 6 hour anti-bump limit - Previous post was at 11:07 PM ----------
Drive Altis like Jetta, Kelisa like mini cooper, BLM like pocket rocket, Kancil like mira mouse deer, it will be a hard act to follow....:banghead:
Actually by complete overhaul, what does it cover?
What is being done/replaced?
Everything. Piston rings, valve seats, maybe even the valves themselves, bearings, gaskets, oil seals, if unlucky maybe new cylinder liners. I didn't quite list everything out but trust me when I say it's a lotta work.
Thank you everyone for your input.. sorry late reply cos busy with assignments the past week..:banghead:
Bro Izso.. tempted with diy-ing now just scared end up making the condition worse.. did the "white paper under the car" for a week but no leaks.. very clean..
spare part shop will have the overhaul kit for your car, but make sure u mention your correct engine model & code, make sure they write the correct part # & model on the receipt, if any part that unable to fit can be returned.
Bro Danz, noted on that.. will go ask around to source for good price..
1. First and foremost, change mechanic.
2. Use a different engine oil, you can try fully synthetic sold at Tesco or Giant at RM99, they do offer from time to time.
3. Inspect the engine bay and look for signs of oil leakage. If your engine bay is all black and sooty, then wash it -- don't spray water on it, use a brush (if you want to save money, get a used toothbrush) with degreaser and gently pour water on a cool engine and wash it top and underneath, this way you can actually SEE if there is any leaks on a clean engine.
4. RM4k to overhaul? Don't waste your money. Save your CASH, buy a Used Proton Savvy Manual for RM7k.
Bro Ixeo.. Got any mechanic nearby subang area to recommend?
Planning to change to a thicker oil at the next oil change..
Inspected, no leaks.. unless i really buta la.. haha..
whats the normal price range for this kind of overhauling? nah.. i love my car too much to get another.. =D
do compression test...
mostlikely just need valve seal replacement
Bro Pomen.. any shop to recommend for compression test? around subang/sunway area best la.. cos studying nearby there..
Bro vr2turbo.. yeap, will change to a thicker oil at next change.. hopefully can help solve the problem..
Bro Izso, was a family car so very jarang abuse la.. but in my hands.. sometimes itchy will go 180 lor... but very rarely la..
After open to check, is there anything need to replace before covering back? Like valve cover removed have to get the gasket to change like bro izso mentioned that day when I ask about removing valve cover/rocket cover/cam cover. Whatever you guys call it.
Drive Altis like XRS, drive kelisa like Gino YRV turbo, Drive BLM like 1.8L and drive kancil like Mira :biggrin: :driver:
Valve cover if old and long time never open then need new one. If valve cover is new can just open and use back...:driver:
Sounds like a serious wear and damage in components. We can do a recommendation of "OAC-modified" if it is wear only but not damage. White smoke may be due to water leak and engine oil consumption could be due to a worn pistoon ring or valve stem. The Last time I witness a similar case was a BMW with a damage worn + chip off at the stem seat..the owner uses VI for a long period of time. Almost all VI contain metal nano particles i order to thicken the oil..prolong use can lead to chokes or wear. In this case, he change 2 stems and the problem was solved.
No white smoke Bro.. but what is OAC-modified?
Hi all the sifu and tai kor here.. problem so far now subsided with oil change to thicker oil..
Share a photo here of my car for you all to see.. I do photography for a hobby/part-time so anyone wants to do photo shoot can la invite.
attachment.php
A thread every 60 seconds
