[DIY] Easiest DIY of all - how to change engine oil
TitanRev
You think I print money?
Mar 3, 2005
8,210
3,678
punk
360
76
Negeri Sembilan
Can use power steering fluid for ATF then? Since is kinda vice versa for whoever said that
i not sure but i used dy in my power steering.:hmmmm:
most probably need to change dy in next service.
---------- Post added at 06:38 AM ---------- 6 hour anti-bump limit - Previous post was at 06:36 AM ----------
That's why, horizontal. Luckily my oil filter is located downwards. No messy job. :biggrin:
Kinda worried after the last ATF change. Saw so much metal shavings on the nut.
u change ur ATF filter before?:hmmmm:
punk
360
76
Negeri Sembilan
Haven't. U?
not yet. dont dare to take the risk.
some say persona using filter mesh.
Based on service manual, to reach the filter need to take down the AT gearbox down.
i saw on LYN persona, the filter picture is same like inside the manual.
Is proven inside gearbox got filter but i still not sure on the vertical pan area..:hmmmm:
ATF filter, Much Bigger job....
ya.
stupidcar
5,000 RPM
Mar 18, 2013
5,567
850
ya.
Ya, Persona one is hard to reach. Idk about it but I heard from spareparts shop they say drop engine only change the filter, or else, they won't. Well, that is a mixed feelings.
15,390
If that is the case don't buy the filter yet we investigate by opening the panel and all first
30,002
That bad ah! Others I see, they remove atf drain pan and can reach it already.
hello ..... can i ask weather there is anyone who knows how to change the meter lights ...... my meter lights doesnt function anymore ...... wira ...... anyone knows how to change the lights ? ....... can i change to another colour ? so does the lights on the a/c switch ? thx
