[DIY] Easiest DIY of all - how to change engine oil
Can use power steering fluid for ATF then? Since is kinda vice versa for whoever said that
i not sure but i used dy in my power steering.:hmmmm:
most probably need to change dy in next service.
---------- Post added at 06:38 AM ---------- 6 hour anti-bump limit - Previous post was at 06:36 AM ----------
That's why, horizontal. Luckily my oil filter is located downwards. No messy job. :biggrin:
Kinda worried after the last ATF change. Saw so much metal shavings on the nut.
u change ur ATF filter before?:hmmmm:
Haven't. U?
Haven't. U?
not yet. dont dare to take the risk.
some say persona using filter mesh.
Based on service manual, to reach the filter need to take down the AT gearbox down.
i saw on LYN persona, the filter picture is same like inside the manual.
Is proven inside gearbox got filter but i still not sure on the vertical pan area..:hmmmm:
ATF filter, Much Bigger job....
ya.
ya.
Ya, Persona one is hard to reach. Idk about it but I heard from spareparts shop they say drop engine only change the filter, or else, they won't. Well, that is a mixed feelings.
If that is the case don't buy the filter yet we investigate by opening the panel and all first
That bad ah! Others I see, they remove atf drain pan and can reach it already.
