tofu_manic
1,342
91
5,148
1. "Sparco" Steering Quick Release (anyone using? does it shake?)
I'd skip this one, wudnt want it to snap while cornering
2. "SARD" Fuel pressure regulator (I am using the standard saga carb, is this upgrade ok? or do I need to change the fuel rail and weber carb also before doing this upgrade?)
SARD fuel pressure regulators are for EFI systems, not carb. FPR's not really needed for carbs. even though they do make them.
3. Arospeed Cam Pulley (or should I use the standard one since I am not going to put in Hi Cam?)
Can use also but for minimal adjustments only. Better if with high cam. Btw my old arospeed cam pulley had excessive wear at the camshaft pin hole area.
4. Mod 1.6 flywheel? (got benefit or the increase in power is not worth the cost & time?)
Never did this, majority of aftermarket flywheels are lighter (not bigger / heavier) to improve response etc. etc. so id rather lighten the standard one instead.
5. Exedy semi racing clutch? (or should I just stick to standard? benefits?)
Go for this if your power levels are such that standard clutch starts to slip and not able to cope.
Thanks in advance to those who reply. Appreciate it.
Reply is above in bold. Cheers!
yyap2
1,146
2
Hi guys, sorry to bump old thread, may I ask if the airbox between 4G13/4G15 Satria is the same?
Is it u young boi new in automotive?
Yes.. ur izzit fuel injection? 1.3 and 1.5 wira and satria is same body chasis... they have same parts mounting point.
---------- Post added at 08:43 AM ---------- 6 hour anti-bump limit - Previous post was at 08:41 AM ----------
Hi
Can some one tell me what is the valve clearance for the 4g13 engine
THX
Wow.... diy?.. u can always google for answer. I forgot about proton wira. . As I always adjust it. Removing the top cover will cost u a new seal.... so get a pro to set it bck for u
synail
259
19
3,018
yes iszo
vdo to vdo
mmc to mmc
no prob pnp
vdo to mmc
mmc to vdo
got prob to mount the sensor
synail
259
19
3,018
airbox for the air filter same but air hose different, vdo had a IAT sensor, proton called that surge tank sensor:hmmmm:
same?:hmmmm:
my bro mmc4G13 got a sensor the size of my palm maf sensor
he want to use my vdo4G13 stock air box but no mount point for his maf sensor:confused:
i can use his open pod no problem w/o the adapter la:biggrin:
later he uses 4G9x stock air box settle
desmond0318
467
48
same?:hmmmm:
haha drill hole and lock nut only ma.. ur bro mod on maf sensor, as i know mmc dosen't produce maf sensor for car below 1500cc those day, they use map sensor.
Have any of you watched the video where Michael Schumacher takes a gorgeous red SLS and loops it in a tunnel? While some are still debating on the authenticity of the commercial, it is still an impressive video nevertheless. I personally like the part where all the crew members are preparing for the run, showing how much preparation, precise calculation and teamwork involved in accomplishing a specific project...
