Mar 18, 2013
Just got a 4g91 fuel injection Auto half cut, planning to install it into my old wira and replace the original 4g15 carb 1.5 auto which has terrible FC. Starts blowing out white smoke once i drive up to 80kmph.
Question is will i get more power in terms of pick up or mid from this 4G91 auto? Will the FC improve as well? This half cut mileage is already 160,000km by the way.
What do i need to change once this engine has been transplanted?
Many thanks.
badguy
951
2
3,018
Many thanks.
bro sure the FC will become better
but since ur halfcut already 160K KM is better to change all tear and wear part togather as well as timing belt set together
1.engine oil (is better to get semi or fully oil - will improve FC also)
2.gear oil (change oil first if got problem u neeed to take out the whole gearbox to gearbox specialist to service)
3.brake oil (i think the forman sure will change for u)
4. aircond gas and oil (I think the forman will change for u also - since half cut come in already cut the pipe)
5.power steering oil (i think the forman sure will change for u)
6.timing belt, oil seal water pump, air cond belt, power steering belt
i think u done the above is good enough already
May 13, 2010
I have a Proton Wira Automatic 1.5 GLI. May I ask where are the horns situated in this car. I cannot see the horn in this car. Thanks for your help.
lai
15,390
lai
More than likely located stock position which is under the signal lamps on the side. People relocate them to the front for ease of installation.
Wira SE (Manual)
Replace new Ori TB as per Mechanic advice but unfortunately didn't help to solve the problem...
According to the mechanic plug cable are ok.
I am using Nasa fully synthetic
You should try changing the plug cables. I don't know how your mech checked the cables. This kind of power loss is usually electrically related.
tofu_manic
1,342
91
5,148
1. "Sparco" Steering Quick Release (anyone using? does it shake?)
I'd skip this one, wudnt want it to snap while cornering
2. "SARD" Fuel pressure regulator (I am using the standard saga carb, is this upgrade ok? or do I need to change the fuel rail and weber carb also before doing this upgrade?)
SARD fuel pressure regulators are for EFI systems, not carb. FPR's not really needed for carbs. even though they do make them.
3. Arospeed Cam Pulley (or should I use the standard one since I am not going to put in Hi Cam?)
Can use also but for minimal adjustments only. Better if with high cam. Btw my old arospeed cam pulley had excessive wear at the camshaft pin hole area.
4. Mod 1.6 flywheel? (got benefit or the increase in power is not worth the cost & time?)
Never did this, majority of aftermarket flywheels are lighter (not bigger / heavier) to improve response etc. etc. so id rather lighten the standard one instead.
5. Exedy semi racing clutch? (or should I just stick to standard? benefits?)
Go for this if your power levels are such that standard clutch starts to slip and not able to cope.
Thanks in advance to those who reply. Appreciate it.
Reply is above in bold. Cheers!
yyap2
1,146
2
Hi guys, sorry to bump old thread, may I ask if the airbox between 4G13/4G15 Satria is the same?
Is it u young boi new in automotive?
Yes.. ur izzit fuel injection? 1.3 and 1.5 wira and satria is same body chasis... they have same parts mounting point.
---------- Post added at 08:43 AM ---------- 6 hour anti-bump limit - Previous post was at 08:41 AM ----------
Hi
Can some one tell me what is the valve clearance for the 4g13 engine
THX
Wow.... diy?.. u can always google for answer. I forgot about proton wira. . As I always adjust it. Removing the top cover will cost u a new seal.... so get a pro to set it bck for u
synail
259
19
3,018
yes iszo
vdo to vdo
mmc to mmc
no prob pnp
vdo to mmc
mmc to vdo
got prob to mount the sensor
synail
259
19
3,018
airbox for the air filter same but air hose different, vdo had a IAT sensor, proton called that surge tank sensor:hmmmm:
same?:hmmmm:
my bro mmc4G13 got a sensor the size of my palm maf sensor
he want to use my vdo4G13 stock air box but no mount point for his maf sensor:confused:
i can use his open pod no problem w/o the adapter la:biggrin:
later he uses 4G9x stock air box settle
desmond0318
467
48
same?:hmmmm:
haha drill hole and lock nut only ma.. ur bro mod on maf sensor, as i know mmc dosen't produce maf sensor for car below 1500cc those day, they use map sensor.
Hi, zthians. Diz is my 1st ever post since i joined zth. Posting diz behalf of my fren.
My fren has Saga LMST, i think yr '04. He wanted to mod his rear brake to disc brake. I hav heard ppl installin rear disc brake of VR4 on Saga. I wanted 2 kno whether is ther any other alternatives to VR4 for Saga?
Thx in advance:
