Hi Guys,
I haven't been here for a while now... for those who did follow my 1st Gen Saga mods, FYI (car is currently under going recovery from an apartment fire).
So 1st up, since I am doing "Project Saga 2 (the recovery)" I need help and advise from some sifu's here about the following...
This is my current car specs that are not standard:
- Naturally Aspired 1.5 (12 valves, Carb, Manual)
- Hotbits Extractor with 1.75" Exhaust.
- Alloy Crank Pulley
- Bosch Super 4 Spark Plugs
- NGK Plug Cable
- ICEEEEE :proud:
- After market steering wheel with boss kit.
- 15" JRD Alloy Rims
- Strut Bar
- Short Shifter
- K&N 3" Open pod air filter
- Razo NA/Turbo Timer
- Swoosh Vacuum & Volt meter
- Zaptor voltage regulator and DIY grounding cables.
I am planning to do the following upgrades, any advise, comments or suggestions?
1. "Sparco" Steering Quick Release (anyone using? does it shake?)
2. "SARD" Fuel pressure regulator (I am using the standard saga carb, is this upgrade ok? or do I need to change the fuel rail and weber carb also before doing this upgrade?)
3. Arospeed Cam Pulley (or should I use the standard one since I am not going to put in Hi Cam?)
4. Mod 1.6 flywheel? (got benefit or the increase in power is not worth the cost & time?)
5. Exedy semi racing clutch? (or should I just stick to standard? benefits?)
Thanks in advance to those who reply. Appreciate it.
