DIY Interior Lights Tapping Dome Light
stupidcar
5,000 RPM
Mar 18, 2013
5,567
850
DIY Make from scratch led light for legroom
As title says.
Pleaseeeeeeeee include step by step explanation.
Or just paste a link to the other thread about this.
Searched on the web, still can't get a good explanation.
thanks in advance.
-Since nobody replied, i have to try it out by myself.
:thefinger:
stupidcar
5,000 RPM
5,567
850
After days and days of finding sources in the internet, i haven't found a steady solution to what I want which is having LEDs installed under the dash(legs there) and on/off like how a dome light does.
I'm driving a Proton Persona Elegance.
So, correct me if I'm wrong.
1) You tap to a cig lighter to the positive then tap the ground to the door sensor.
2) Direct tapping from the dome light's -/+ festoon bulb holder.
3) Tapping the 2 wires from the wires of dome light. (Which I doubt it is gonna give me on/off switches function.
4) Any other solutions? I don't wanna tap headlight or taillights.
15,390
Why not just find a live wire under the dash, then connect to that and the door switch? That way it'll follow whenever the door opens up?
stupidcar
5,000 RPM
5,567
850
Aih, so sad nobody wanna reply me. As in tap any live wire(Cig lighter), then negative wire to the negative wire of door sensor? If i wanna on whenever i want, must open door lor?
15,390
Well in that case why not just tap hte live wire from ciglighter then negative connect to a switch la. Then you can control on or off mah. Simple!
Dayline668
1,828
492
1,683
Just tap the wire inside the dome light housing, newer car dome light will on when u open alarm, b4 u start the car the light will slowly dim, then u can on off it also. By using a meter u can trace which connector to tap under your dashboard, if u dun know electric stuff better go to workshop to do it, to avoid frying your wiring.
stupidcar
5,000 RPM
5,567
850
So let me get this straight.
1st, disconnect Battery first.
2nd, tap the live wire of cig lighter or the dome light live wire, then the negative one put to the negative of door sensor?
OR,
I should just tap at the festoon metal holder inside the dome lights?
15,390
OR,
- Leave the battery in first then test to see which is the live wire.
- Disconnect battery (not really necessary but safe better than sorry)
- Connect to the live wire you tested earlier to a switch which you can mount anywhere
- Connect the switch to the Live and ground it to the chassis.
Then you can control the LED lor.
Oh btw, I assume this it the leg well LED right?
stupidcar
5,000 RPM
5,567
850
Yeah, it is. I want to control the lights using dome light functions woi. Like the door opens, the lights will on.
15,390
Oh in that case just tap the dome light trigger and take power from ciglighter. Also install a switch so you can disable it whenever you want. If you're ok with electronics, add the switch in such a way it's either "always on" or "follows door trigger". :biggrin:
stupidcar
5,000 RPM
5,567
850
DIY done. Done by tapping long wire from the dome light bulb holder. directly. Looking good. Changed my number plate lights to white too. A pain in the ass to change it. I wonder why would Proton persona people design it like that.
stupidcar
5,000 RPM
5,567
850
show pictures la!
All wires are on the roof, pillars, and rubber door seals. All did neatly unless u look under the dash. Haha. My camera settings are not that good. But look at the floor mat lah, it's white.
:biggrin: :biggrin: :biggrin: :biggrin: :biggrin: Sometime soon, i will do back seat too. Er Izso, u know where to get those Mugen or Type R 4th brake light? I like the light to be rectangular, not triangle(ugly). And also white in colour
Each side only 5SMD white led. I don't want to use led stripe because its too freaking bright. This brightness is just the way i like it. :hello:
hAz
397
2
congrats on your diy bro..
i did mine with just a simple on off switch.. which i leave it on 24/7..hehe
i use blue LED strips..not as bright as white strips i guess..
hAz
397
2
Oh ur's less hassle. But i like the fact that the lights are on when the door is opened. :biggrin: :congrats:
yah, id like to have that too..:adore:
will find time to mod mine later..hahah.. maybe will post photo if i mod mine.
twistedichc
Jan 22, 2013
2,930
255
683
Ampang Point
or u can tap it to your ICE head unit like i did mine. but to insure the fuse in fuse box for the HU doesnt burnt out u might need to change 2 slightly hire amp. here how it works:-
1) make sure u take out both batt terminal
2) find ur HU yellow (batt supply), blue (remote/ ignition) & black (ground) wire (usually)
3) tap +ve led to blue & -ve to black
4) in this case the led will only on when you start your car & always on
Hello, bros.. recently i found another extra voltage stabilizer which is hot inazma and the one i am using currently is raizin so just wondering can any experts here tell me that whether a not i can install both of the voltage stabilizer in my wira ?? meaning 2 voltage stabilizer, will it causes more harm than good?
