Myvi 1.5 se with original suspension stiff ride
ericartman
21
Anyone can give me suggestion on what need to be changed for stiff ride of Myvi SE 1.5? Its quite stiff for me, not quite comfortable.
I was thinking changing front and back spring:
SUSTEC Comfort Sport Spring PERODUA MYVI - Car Accessories & Parts for sale Selangor - Mudah.my
or
ORI S RACING Comfort Sport Spring Made in Japan - Car Accessories & Parts for sale Selangor - Mudah.my
But im not sure on the comparison with the default spring stiffness. I can only assume that its more comfortable as it says comfort.
Then I was thinking on getting fully adjustable, like this one, cause im afraid that spring change only does not give the same height on front and back:
GAB ADJUSTABLE SS Series for myvi - Car Accessories & Parts for sale Selangor - Mudah.my
But planned budget is less than 1k rm, prefer not to take fully adjustable.
If there's anyone with experience with this, please let me know, thanks.
ixeo
4,788
3,080
KL, Malaysia
If stock is stiff, everything else will be worst. True story.
cvkit17
2,884
1,354
Try getting a lower k value spring. Myvi 1.5 original suspension is really stiff, uncomfortable, and rubbish in handling. I believe yours is a new car, isn't it? Initially the suspension is very stiff but after awhile like 6-8 months, the ride becomes more comfortable. I don't know about the aftermarket comfort sport springs you mentioned, but as the name sport spring implies, it's gonna be a lowered one and might and might not be bumpy. Suggest you go through the reviews first.
Suggest you not to take gab SS. It's gonna be a hell lot stiffer than stock even on the softest setting. I personally using KYB RS Pro and I am very happy with it. The stiffness is comparable to stock or a little bit more. But with active valve system and lowered height, the handling is much more better and safer.
ericartman
21
How do I determine K value on a spring by looking? By say looking at the gap between the loop?
I bought it close to 1 year ago. Still have the same stiffness.
Your KYB RS Pro, is it completely adjustable? Yours both spring and absorber right?
cvkit17
2,884
1,354
You can't by just looking at it. Some manufacturers printed the k value on the coil but some don't. Just gotta dig deeper if its on stated on the product. KYB RS Pro isn't fully adjustable. It's only HI/LO but unlike other hi/lo adjustable, it is soft. If comfort is your priority, I don't recommend adjustable shocks. Perhaps you can look into other absorber brands and other OEM springs with lower k value.
LesleyAprotto
Banned
Jun 16, 2012
1,339
287
683
Dear Eric,
I think you may not have to change the suspension at all...
You can opt for a set higher profile tyre for example if your current tyres are 55 series, you can change to 60 series
Another alternative is to change to softer tyres, example Michelin XM-2
Another is to lower your tyres air pressure, for example if its at 33psi you can down it to 31 psi.
Hope its a cheaper alternative than to change the whole suspension system which I think its wasteful as your ori suspensions
are still quite new...
ronaldindin
207
29
www.12bet.com
what if add in a spring coil buffer. Heard that this product may make the ride more comfortable. anyone using?
coil buffers are supposed to help sagging springs la, not to soften them.
ericartman : How much do you travel? Perhaps your absorbers is worn out. Trust me on this - nothing is more comfortable than stock. Changing to any of those springs you highlighted will make your ride even more stiffer. Stock is the softest you can get. It's most likely your spring and/or absorber is worn out so check for oil leaks on your absorbers. Kayaba is the OEM manufacturer so buy back the same Kayabas. You can probably try to opt for Monroe Reflex absorbers paired with stock springs too.
YYC : 1.3 will fit in the 1.5 car meh? Wouldn't the front dive since the engine is bigger/heavier?
cvkit17
2,884
1,354
I don't think his absorbers are worn out..coz originally myvi 1.5 suspension is really stiff and uncomfortable. I remember the first day I got my car, I felt that the suspension is stiffer than 1.3. So I thought to myself maybe the handling is better since it is revised. Cruised a 40-50 degree corner at around 50-60kmh...crap...feel like I'm gonna lose my new car by rolling it into the drain.
I'm not sure which part of 1.5 suspension is different from 1.3. The spring or the absorber. Probably the absorber as the bouncing rate is low, therefore it feels stiff.
1.3 can fit into 1.5...almost identical.
put 1.3 suspension la then
ericartman
21
You dont plan to change yours? Cause I started to feel uncomfortable, I dont drive fast that often.
There was a time that i drove to penang from KL through NKVE which shows the stiff ride advantage, the car felt tremendously stable at straight line. But dont do it quite often, prefer comfort normal daily ride.
guys, i need ur help
my car is wira aeroback
few weeks ago i found out my car suddenly stinks...
feel so weird bcos my car using glade air freshner, it used to b dam nice smell once i open the car's door.
few days later, i realise the under the rubber mat on my driver side is wet.
the carpet is wet. only my driver side.
then i did checking... no water leak from the door... n under also no problem
water should b leaking from somewhere around the fire wall...
who got this experience...
